AI-1608AY-USB是USB2.0高精度模拟量输入终端
AI-1616LI-PE是PCI Express总线16位隔离型模拟量输入接口板
AI-1616L-LPE是PCI Express(Low Profile size)总线高精度非隔离模拟量输入接口板
PCI Express(Low Profile size)总线高精度非隔离模拟量输入接口板,It is an analog input terminal for USB2.0 that an analog measurement is possible by being connected to USB interface. You can use analog input (16bit, 8ch), digital input (LVTTL 4points), digital output (LVTTL 4 points) with this one product. Using attached data logger software [C-LOGGER], No-programing data collection is possible. In addition, The windows applications can be made such as by Visual Basic or Visual C++ if using an attached driver library.
AI-1616LI-PE是PCI Express总线16位隔离型模拟量输入接口板,This product is a PCI Express bus-compliant interface board used to provide an analog signal input function on a PC. It features bus isolated 16-bit analog input 16 channels. Equipped with digital I/O and counter, this product is multifunction and bus isolated type that provides isolation between PC and external analog I/O circuit. This product carries buffer memory for 1K of data, allowing sampling to be performed in a variety of trigger / clock conditions. Windows/Linux driver and full-fledged data logger software [C-LOGGER] is bundled with this product.
AI-1616L-LPE是PCI Express(Low Profile size)总线高精度非隔离模拟量输入接口板,This product is a multi-function interface board of the PCI Express bus conformity that carried digital input and output (LVTTL level, for each 4 points) and counter (32bit, 1ch) as well as analog input of highly precise 16bit. It supports a Low Profile size slot and a standard size slot by changing an attached bracket. Attachment windows/Linux version driver. In addition, the product also supports MATLAB and LabVIEW with plug in of an exclusive library(free download).
