产品名称: 康泰克AI-1664LA-LPE、AI-1664LAX-USB、AIO-121601E3-PE
型  号: AI-1664LA-LPE
品  牌: 康泰克contec
AI-1664LA-LPE是PCI Express(Low Profile)总线100KSPS 16位模拟量输入接口板
AI-1664LAX-USB是USB 100KSPS 16位模拟量输入单元
AIO-121601E3-PE是PCI Express总线 100KSPS 12位模拟量I/O接口板
AI-1664LA-LPE是PCI Express(Low Profile)总线100KSPS 16位模拟量输入接口板,This product is a Low Profile, PCI Express bus-compliant interface board used to provide an analog signal input function on a PC. This product is multi-channels and multifunction type with 16-bit analog input 64 channels (single-ended input 64 channels or differential input 32 channels), digital I/O and counter function. This product carries buffer memory for 1K of data, allowing sampling to be performed in a variety of trigger / clock conditions. Windows/Linux driver and full-fledged data logger software [C-LOGGER] is bundled with this product.
AI-1664LAX-USB是USB 100KSPS 16位模拟量输入单元,This product is a USB2.0-compliant analog input unit that extends the analog input function of USB port of PCs. This product is multi-channels and multifunction type with 16-bit analog input 64 channels (single-ended input 64 channels or differential input 32 channels), digital I/O and counter function. This product carries buffer memory for 1K of data, allowing sampling to be performed in a variety of trigger / clock conditions.
AIO-121601E3-PE是PCI Express总线 100KSPS 12位模拟量I/O接口板,This product is an unisolated PCI Express bus-compliant interface board that expands the I/O function of a PC for analog signals. This product carries high-capacity buffer memory for 16MB of data for analog input, allowing background sampling to be performed in a variety of trigger conditions.
关 键 词: AI-1664LA- AI-1664LAX AIO-121601
公司名称: 北京瀚智伟业科技有限公司
联 系 人: 陈工
电  话: 010-400-997-2299
手  机: 13381390983
地  址: 北京市海淀区中关村东路89号恒兴大厦14层D室
邮  编: 100190
IEI威强工控机RACK(RACK-360G)
研华PPC3150160(PPC31501601E-T)
研华工控机IPC-713(IPC-7132)
研华TPC-1251T-(IPPC-6172A-R2AE)
艾默生UPS电源UHA1(UHA1R-0020)
艾默生02k00TS11(06k00TE1101C00)
研华ARK-3500P-(ARK-3500P-00A1E)
AIO-121601E3(AIO-160802AY-USB)
康泰克AIO-12160(AIO-121602AL-PCI)
研祥工控机820、IPC(IPC-820)
BX-200-DC500(BX-210D-DC5311)
COM-4(PCI)H、(COM-8(PCI)H)
IPC-820、研祥工控(IPC-820)
IPC-5120、ACP(IPC-5120)
PCE44/9P4S、C(COM-4C-LPE)
ACP-2010、IPC(ACP-2010)
IPC-5120、IPC(IPC-5120)
研华工控机IPC-712(IPC-7120)
艾讯工控机AX-6140(AX-61400)
研华ACP-2010MB(ACP-2010MB)
