C34 IGBT缓冲吸收电容器
型号
规格
价格(元)
尺寸(mm)
引出
C34
0.33vF/1200
5
42.5*15*26 P=37.5
d=1.2
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于UPS、逆变器、感应加热、电焊机等设备的IGBT模块吸收保护。
Widely used in UPS,inverter,induction heaters,welding machine for IGBT snubber protection.
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:双面金属化与金属化膜内串结构
封装:塑料外壳,阻燃(94V-0级)环氧封装
引出:镀锡铜线
能承受高脉冲电流,高dv/dt
ESL,ESR小
具有自愈性
Dielectric:Polypropylene film
Construction:Extended double side metalized carrier film with internal series connection and metalized film
Coating:Resistant plastic case with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:Tinned copper lugs
High pulse current,high dv/dt
Low ESL and ESR
Self healing
技术性能/Specifications
引用标准/Reference standards
GB/T 17702 IEC 61071
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
0.0068μF~5.6μF
额定电压/Rated Voltage
700Vdc~3000Vdc
容量偏差/Tolerance
±5% ±10%
极间耐电压/Test voltage between terminals
1.5Ur(Vdc)10s 25℃±5℃
极壳耐电压/Test voltage between terminals and case
3000V 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor
tgδ≤6×10-4 at 25℃±5℃,1kHz
绝缘电阻/Insulation resistance
C×R≥30000s,at 100Vdc,25℃±5℃,60s
预期寿命/Life expectancy
200000h at Ur and 70℃
此产品关键字:IGBT吸收电容、IGBTSNUBBER、IGBT吸收电容厂家、IGBT吸收电容价格
华裕电容-高品质金属化薄膜电容专业制造商
