C46谐振电容器
型号
规格
价格(元)
尺寸(mm)
引出
C46
0.1/vF/1200V
10
D44*L 44
M6.M8
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于大功率的高频谐振设备中
Widely used in high power high frequency resonant device
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:双面金属化与金属化膜内串结构
封装:外包阻燃迈拉胶带,阻燃(94V-0级)环氧封装
引出: M6铜螺母或焊片引出
高电压、高频率、高dv/dt特性
能承受大电流
Dielectric:Polypropylene film
Structure: double metal and metal film inner series structure
Coating:Polyester tape wrapping with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:M6 copper nut or lug
High voltage, high frequency, high dv\/dt characteristics
Can withstand high current
技术性能/Specifications
引用标准/Reference standards
GB/T 17702 IEC 61071
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
0.06μF~8μF
额定电压/Rated Voltage
1200Vdc~5000Vdc
容量偏差/Tolerance
±5%;±10%
极间耐电压/Test voltage between terminals
1.5Ur 60s 25℃±5℃
极壳耐电压/Test voltage between terminals and case
3000V 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor
tgδ≤10×10-4 at 25℃±5℃,1kHz
绝缘电阻/Insulation resistance
C×R≥5000s,at 100Vdc,25℃±5℃,60s
耐电流冲击能力/Withstand strike current ability
dv/dt>1000V/μs
杂散电感/Stray inductance
≤30nH
有效电流/Effective current
30A~100A
预期寿命/Life expectancy
200000h at Ur and 70℃
此产品关键字:高频高压谐振电容、谐振电路电容的功能、谐振电容的影响
华裕电容-高品质金属化薄膜电容专业制造商
