C47 高压谐振模块电容
主要应用 Application
●广泛应用于商用电磁炉和感应加热设备的半桥、全桥谐振电路。
●Widely used in half-bridge,full bridge,s resonant circuit of commercial induction cooker and induction heater.
产品特点 Characteristics
电介质:聚丙烯薄膜
●Dielectric:Polypropylene film
结构:金属化膜干式结构
●Construction:Extended metalized film,dry connection
封装:金属铝外壳,阻燃(94V-0)环氧封装
●Coating:Aluminum case with resin sealing.Flame retardant execution(UL94V-0)
引出:镀锡铜螺母
●Terminals:Tinned copper nut extraction
具有耐压高,电流大,体积小,温升低,寿命长等优点。一体化铝壳散热结构,直接紧贴散热片散热。机芯内部可做全密封、防水、防油烟等。
●Withstand high voltage,heavy current,small size,low temperature rise,long lifetime.Inregrated aluminum radiant structure,close to the radiant panel.The internal movement of the modules are sealed,waterproof and so on.
典型链接图/ Typical link figure
半桥结构 全桥结构
性能指标 Specifications
引用标准/Reference standards
GB/T17702 IEC61071
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
2×(0.4~1.4μF)
额定电压/Rated Voltage
1200VDC~4000VDC
电容量偏差/Tolerance
±5%、±10%
损耗角正切值/Dissipation factor
tgδ≤10×10-4 1KHz 25℃±5℃
极间耐电压/Test voltage between
1.5Ur 10S 25℃±5℃
极壳耐电压/Test voltage between and case
3,000VAC 50Hz 60S 25℃±5℃
绝缘电阻/Insulation resistance
RC≥5000S,at 100VDC ,60S 25℃±5℃
耐电流冲击能力/Withstand strike current ability
dv/dt≥1000V/μs
有效电流/Effective current
30A~100A
杂散电感/Stray inductance
≤30nH
预期寿命/Life expectancy
200,000h at Ur and 70℃
产品编码/Part Numbering Systen
产品外形及参考尺寸/Product shape and size for reference
半桥用产品结构 全桥用产品结构
常规尺寸/ Regular size
Un=2500V.DC
CAP
(μF)
Part Number
参 考
功 率
L
(mm)
T
(mm)
H
(mm)
P1+P2
(mm)
Irms
(A)
dv/dt
(V/μs)
引出方式
2×0.9
C472522×904JF-01
半桥15KW
175
74
450
33+28
2×90A
1000
M8+2×M6螺母
Un=3000V.DC
CAP
(μF)
Part Number
参 考
功 率
L
mm
T
mm
H
mm
P1+P2
(mm)
Irms
(A)
dv/dt
(V/μs)
引出方式
2×0.6
C473022×604JF-01
半桥8~12KW
165
65
45
33+28
2×60A
1000
M8+2×M6螺母
2×0.8
C473022×804JF-01
半桥15~20KW
175
74
45
33+28
2×80A
1000
M8+2×M6螺母
2×1.0
C473022×105JF-01
半桥20~25KW
195
85
45
33+28
2×85A
1000
M8+2×M6螺母
2×1.2
C473022×125JF-01
半桥25~30KW
195
85
45
33+28
2×90A
1000
M8+2×M6螺母
Un=3600V.DC
CAP
(μF)
Part Number
参 考
功 率
L
(mm)
T
(mm)
H
(mm)
P1+P2
(mm)
Irms
(A)
dv/dt
(V/μs)
引出方式
1.0
C47362105JFM8-01
全桥30KW
175
74
45
56
120A
1000
2×M8螺母
1.2
C47362125JFM8-01
全桥40KW
195
85
45
56
140A
1000
2×M8螺母
1.35
C473621355JFM8-01
全桥50KW
205
94
45
56
150A
1000
2×M8螺母
