C56直流链电容
型号 规格 价格(元) 尺寸(mm) 引出
C56 150vF/700V 160 D85*L 51 M6
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于UPS、SMPSs,逆变电源、焊机电源等设备中起直流支撑和滤波。
DC-Link and filter for UPS,SMPSs,inverter,welding machine power.
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:金属化膜干式结构
封装:塑料外壳,阻燃(UL94V-0级)环氧封装
引出:镀锡铜螺母或螺杆引出
高稳定性
低 ESR,ESL
具有自愈性
Dielectric:Polypropylene film
Construction:Extended metalized film ,dry connection
Coating:Aluminum case with resin sealing.Flame retardant
execution(UL94V-0)
Terminals:Copper nut or screw leads
High stability
Low ESR,ESL
Self healing
技术性能/Specifications
引用标准/Reference standards GB/T 17702 IEC 61071
工作温度范围/Operating temperature range -40℃~85℃
容量范围/Capacitance 80μF~1000μF
额定电压/Rated Voltage 500Vdc~2000Vdc
容量偏差/Tolerance ±5% ±10%
极间耐电压/Test voltage between terminals 1.5Ur(Vdc)10s 25℃±5℃
极壳耐电压/Test voltage between terminals and
case
3000V 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor tgδ≤2×10-3 at 25℃±5℃,100Hz
绝缘电阻/Insulation resistance C×R≥5000s,at 100Vdc,25℃±5℃,60s
预期寿命/Life expectancy 200000h at Ur and 70℃
此产品关键字:直流支撑电容器、DC-LINK、直流链电容
华裕电容-高品质金属化薄膜电容专业制造商
