型号
Basic complete set:
基本完整组件
KIT 230 R
"A" series server 86 AR 230
+ Configuration configuration cable 07SK 50
+ Configuration assistant CW 50, (on diskets)
+ Back-up CD-ROM including:
Copies of Configuration assistant and Start-up manual and User's guide
Note: The printed copies of Start-up manual and User's guide are not included.
"A" Series Servers
"A" 系列 Servers
86 AR 230
86 AR 24
86 AT 24
Extensions (digital I/O)
扩展模块 (数码 I/O)
16-00X
00-08 XR
04-04 XR
00-16 XT
08 XC
XD 8
Extensions (analog inputs)
扩展模块 (模拟输入)
08-00XA
Miscellaneous equipment
其他设备
07 SK 50
07 ST 50
CW 50
Straight key
直锁
LS31P16B11
LS31P16D11
Steel plain plunger
钢锁
LS31P11B11
LS31P11D11
Plastic roller plunger
塑料滚轮棒
LS31P13B11
LS31P13D11
12.5 Plastic roller lever with steel plunger
直径12.5mm塑料滚轮棒
LS31P31B11
LS31P31D11
LS31P32B11
LS31P32D11
Ø 18 Polyamide roller lever
直径18mm尼龙滚轮棒
LS31P41B11
LS31P41D11
Adjustable lever with Ø 3 fibre-glass rod
直径3mm可调较纤维杆
LS31P72B11
LS31P72D11
Spring rod
弹簧杆
LS31P91B11
LS31P91D11
LS31P Limit Switches -40mm Width
LS31P 限位开关参考定价
型号
Steel plain plunger
钢棒
LS40P11B11
LS40P11D11
Steel roller plunger
钢滑轮棒
LS40P13B11
LS40P13D11
Ø 22 polyamide roller with lever
直径22mm尼龙滚轮棒
LS40P41B11
LS40P41D11
Ø 45 Rubber roller with lever
直径45mm橡胶滚轮棒
LS40P44B11
LS40P44D11
Ø 22 Polyamide roller with adjustable lever
直径22mm可调较尼龙杆
LS40P51B11
LS40P51D11
Ø 45 Rubber roller with adjustable lever
直径45mm可调橡胶滚轮棒
LS40P54B11
LS40P54D11
Ø 6 mm Polyamide adjustable lever
直径6mm可调较纤维杆
LS40P72B11
LS40P72D11
Stainless steel plain plunger
不锈钢棒
LS40M11B11
LS40M11D11
Steel roller with plunger
不锈滚轮钢棒
LS40M13B11
LS40M13D11
Ø 22 Polyamide roller with lever
直径22mm尼龙滚轮棒
LS40M41B11
LS40M41D11
Ø 22 Stainless steel roller with lever
直径22mm不锈滚轮钢棒
LS40M42B11
LS40M42D11
直径45mm可调橡尼龙棒
LS40M51B11
LS40M51D11
Ø 6 mm Adjustable polyamide rod
直径6mm可调橡尼龙棒
LS40M72B11
LS40M72D11
LS31P Limit Switches -60mm Width
LS31P 限位开关参考定价
型号
不锈钢棒
LS60M11B11
LS60M11D11
Stainless steel roller plunger
不锈滚轮钢棒
LS60M13B11
LS60M13D11
Side plunger with horizontal roller
直径22mm尼龙滚轮棒
LS60M31B11
LS60M31D11
直径22mm尼龙滚轮棒
LS60M41B11
LS60M41D11
Spring rod
弹簧杆
LS60M91B11
LS60M91D11
Foot Switches
脚用开关参考面价
型号
Free movement
自动移动脚用开关
IPSY1A11
IPSY1D11
Locked in normal position
锁于一般位置脚用开关
IPSY2A11
IPSY2D11
Locked in low position
锁于低位置脚用开关
IPSY3A11
IPSY3D11
Free movement mini foot switch
自动移动, 迷你脚用开关
IPM2Y
IPM2B
