尺寸标准:Qseven 70 x 70 mm
处理器: AMD G-T40E 1.0 GHz Dual Core (L1 cache 64KB, L2 cache 512kB x2, 6.4 W)
AMD G-T40R 1.0 GHz Single Core (L1 cache 64KB, L2 cache 512kB, 5.5W)
内存:在板 2G DDR3L-1066(4GByte 可选)
芯片:AMD A55E Controller Hub
以太网:Intel 82574千兆以太网
I/O接口:4x PCI Express x1 lanes,
2x Serial ATA
8x USB 2.0
1x SDIO to 8bit SD/MMC
2x ExpressCard, LPC Bus, I2C Bus
存储:板载SATA电子盘,最大32G ( 可选)
声音:高清晰音频接口
显示:Integrated AMD Radeon HD 6250
DirectX11 graphics with UVD 3.0
Dual Simultaneous Display Support
LVDS:支持LVDS 18 bit、24bit及24 bit双通道,
分辨率1920*1200@60HZ
数字显示:DisplayPort 1.1a or HDMI 1.3 port
分辨率 1920x1200@60Hz
特征:AMI-Aptio 4MByte Flash BIOS with congatec Embedded BIOS features
电源管理:ACPI 3.0 with battery support
操作系统:Microsoft Windows7, Windows XP, Windows embedded Standard, Linux 2.6
功耗:典型应用程序 tbd.
温度:运行,0 to +60°C ,可提供-40°C~85°C军工级别宽温产品
存储,-20 to +80°C
湿度:运行,10-90%r.H非冷凝
存储,5-95%r.H非冷凝
尺寸:70 x 70 mm (2.76” x 2.76”)
