产品规格
Mini ITX 170x170mm (6.7”x 6.7”)
处理器
Intel Atom x7-E3950 (4x1.6/2.0GHz,2MB L2 cache,12W)
Intel Atom x5-E3940 (4x 1.6/1.8GHz,L2 cache 2MB,9W)
Intel Atom x5-E3930 (2x 1.3/1.8GHz,L2 cache 1MB,6.5W)
Intel Pentium N4200 (4x 1.1/2.5GHz,L2 cache 2MB,6W)
Intel Celeron N3350 (2x 1.1/2.4GHz,L2 cache 1MB,6W)
内存
2x SO-DIMM sockets (dual channel DDR3L up to 1866 MT/s) to support a max. memory size of 8GB
网络
2x Intel® I211 Gigabit Ethernet controller (Commercial) | 2x Intel® I210
Gigabit Ethernet controller (Industrial)
声音
High Definition Audio Interface with Cirrus CS4207
图像
Intel® Gen 9 HD Graphics
Support for DirectX12 | OpenGL 4.3 | OpenCL 2.0 | OpenGLES 3.x |
MPEG2 full HW acceleration with H.265/HEVC decoding and H.264
encoding | VP9 | PAVP 3.x | HDCP 1.4 | MVC and 2x independent display
support in 4K (3840 x 2160 px) @30 Hz or WQXGA (2560 x 1600 px)
@60 Hz
输入接口
1x PCIe x1 Slot shared with mPCIe
1x mPCIe Half Size shared with PCIe slot
1x M2 (Supported card sizes: 2242 and 2230)
2x SATA (one shared with M2)
1x SATA Power connector (header)
1x SATA Power
1x USB 3.0/2.0 Header
1x USB 3.0 (on M.2 slot)
1x USB 2.0 (on miniPCIe slot)
1x microSD card slot
1x SIM Card slot
1x Embedded DisplayPort 1.3
1x Backlight (Power | Control)
1x Front Panel HD Audio
2x Serial Port COM2 (opt. as ccTALK)
1x Frontpanel (Power Switch, LEDs, Reset)
1x FAN CPU
1x FAN System
1x internal power header (12-24V)
1x opt. battery header signal + power (SBM3)
输出接口
2x DisplayPort dp++
1x LVDS 2x24 bit/shared with eDP 1.3
3.5mm Audio In and 3.5mm Line Out
2x LAN RJ45
2x USB 3.0
2x USB 2.0
1x DC-In (external input) 12-24 V
康佳特板载控制器
Multi Stage Watchdog, non-volatile User Data Storage, Manufacturing and
Board information, Board Statistics, BIOS Setup, Data Backup, I²C bus
(fast mode, 400 kHz, multi-master), Power Loss Control
嵌入式BIOS
AMI Aptio® 2.X (UEFI) BIOS
BIOS Update
Logo Boot
Quiet Boot
HDD Password
安全
The conga-IA5 can be optionally equipped with a discrete ”Trusted Platform
Module” (TPM 1.2/2.0).
It is capable of calculating efficient hash and RSA algorithms with key
lengths up to 2,048 bits and includes a real random number generator.
Security sensitive applications such as gaming and e-commerce will benefit
also with improved authentication | integrity and confidence levels
电源管理
Power Management | ACPI S3/S4 DeepSx | Wake on time from S5 | Power
Supply 12-24 V | 2x fan (CPU / system) monitored & controlled
支持操作系统
Microsoft Windows 10
Microsoft Windows IoT Core
Linux
Android
Wind River VxWorks 7
温度
Extended
Operating: -40°to + 85°C Storage: -40°to + 85°C
