上海欧朔生产的全伺服水平式卷膜制袋包装机的特点及参数
EQUIPMENT FEATURE AND PARAMETER:
1.可实现数据调取,一键式切换;
Data retrieval ability with one-button switching facility
2.全伺服结构,更加简单稳定、噪音更小;
Fully servo structure, simpler and more stable, less noise
3.封合采用伺服跟随定位,减少封口允许误差,提升包装美观度;
Servo-followed Poistioning sealing, reduce allowable sealing error and improves aesthetics of packaging
4.设备采用全新控制系统,提升OEE设备综合效率;
Adopts a Fully new control system to improve the comprehensive rate of OEE equipment
5.具备运转机构监视功能,更加具备安全性;
Equipped with running mechanism monitoring function, adding better security
6.设备更加智能,降低对操作人员的要求;
The equipment is more intelligent which reduces the requirements for operators
