产品介绍: |
1 Background suppression 1 Sealed to IP 65 1 200 to 1500 mm (7.87 to 59.05 in.) range 1 Die cast zinc limit switch style housing 1 Temperature compensated, ±1% 1 Analog output proportional to sensor-totarget distance 1 Field adjustable analog output slope 1 Two independently adjustable digital setpoints, PNP N.O. outputs 1 Inhibit input for multiple sensor synchronization
