1200W Parallel Switching Power Supply ·AC 200~260V input only ·保护: 短路/过压/过载/超温 ·High reliability/Low ripple noise ·Built-in remote sense function ·Built-in remote ON-OFF control ·With parallel function (N+1) ·Can adjust from 10~100% output voltage by external control 1-5V ·内置直流风扇强制风冷 ·Case coating with paint ·2年保修 (291×132×132mm)
