45W Single Output Industrial DIN Rail Power Supply ·Universal AC input/Full range ·UL508 listed approved ·Installed on DIN rail TS35/7.5 or 15 ·认证: UL/CUL/TUV/CB/CE ·保护: 短路/过载/过压/超温 ·开关频率: 100KHz ·LED indication for power on ·自然风冷 ·100% 满载烧机测试 ·3 年保修 (93×78×67mm)
