产品介绍: |
·开关选择交流输入范围 ·Passive PFC>0.65 (option) ·Battery charger for lead-acid ·Built-in ON-OFF power switch ·3 poles inlet with fuse holder ·Deep discharge start function ·Charge type can be selected (option) ·保护:短路/过载/过压/超温 ·2 color LED loading indicator ·认证: UL/CUL/TUV/CB/CE ·EN60335 approved ·Open frame type available ·低价格, 高可靠 ·2 年保修 (180×96×49mm)
