| 产品名称: |
瑞传网络通讯平台周边配件 ABN-192
| 型 号: |
ABN-192 |
| 价 格: |
| 品 牌: |
瑞传(Portwell) |
产品介绍: |
- Dual 64-bit Gigabit Ethernet ports base on Intel® 82546GB controller
- Supports 133MHz PCI-X bus and backwards compatible with 64/32-bit PCI
- Built-in Watchdog Timer (WDT) to switch Ethernet ports bypass mode3 by system hang and power failure
- Easy configuration of Normal/Bypass mode and WDT time-out by hardware setting or software programming
- Built with both on-board LED and LED pin-out for LAN status and bypass mode, provides variable LED location for system integration
- Specifications are subject to change without notice.
- Pentium® 4, Pentium® III, Pentium® II and Celeron® are registered trademarks of Intel® Corporation.
- Xeon8482; is a trademark of Intel® Corporation.
- Other trademarks, logos, brands and company names are the property of their respective owners.
| 关 键 词: |
ABN-192 |
