产品名称: Mini ITX MX700CXM
型  号: MX700CXM
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
VIA C7 1 GHz onboard
FSB
400/533 MHz
BIOS
Award 4Mb Flash BIOS
System Chipset
VIA CX700/M
I/O Chip
Winbond W83627HG-AW
System Memory
1 x 240-pin DIMM sockets support max. 1 GB DDR2 400/533 memory. Supports EEC for DDR2 400 only
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant)
I/O
MIO
1 x EIDE (Ultra DMA 133), 1x LPT, 2 x SATA, 4 x RS-232 (COM2 support RS422/485, 1 x K/B, 1 x Mouse
IrDA
115k bps, IrDA 1.0 compliant
USB
6 x USB 2.0 ports
DIO
16-bit General Purpose I/O for DI and DO
Display
Chipset
Integrated UniChrome Pro 3D/2D Graphics & Video processor
Display Memory
UniChrome Pro 3D/2D Graphics & Video processor supports up to 128 MB video memory
Resolution
1920 * 1200 @ 32 bpp (85 Hz)
Dual Display
CRT + LVDS, LVDS, or CRT
LVDS
VIA CX700 supports Single channel 18/24-bit/Dual-channel 36-bit LVDS
Audio
Chipset
VIA CX700
AC97 Codec
Realtek ALC883 supports 5.1 CH Audio
Audio Interface
Mic in, Line in, Line out
Gigabit Ethernet
LAN1
Realtek RTL8100C 10/100 LAN
LAN2
I/O
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x Serial port
1 x VGA port
4 x USB 2.0/1.1
2 x RJ45 port
8-Channel Audio I/O ( 3 jacks )
Internal I/O Connector
1 x USB connectors support additional 2 USB ports
1 x 20-pin ATX Power connector
1 x IDE connector for two devices
1 x Floppy disk drive connector / slim
3 x COM connector
1 x CPU Fan connector
1 x Chassis Fan connector
1 x LVDS connector
1 x TV connector
1 x LVDS inv connector
1 x Audio connector
1 x CD_In connector
1 x GPIO
1 x Front panel
Mechanical & Environmental
Power Requriement
+5 V @ 1.745 A, +12 V @ 0.202 A, +3.3 V @ 0.721 A, 5 Vsb @ 0.23 A (with VIA C7 1.0 GH & 512 MB DDR2 SDRAM)
Power Type
ATX
Operating Temperature
0~60C(32~140F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88lbs (0.4kg)
Ordering Information
MX700CXM
VIA C7 1 GHz Mini ITX Main Board with VGA, 2-CH LVDS, 5.1 CH Audio, Dual (Giga) LAN, PCI, & 6 USB 2.0
关 键 词: 嵌入式 主板 MX700CXM
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
