产品名称: Mini ITX IX910GMLE-C6
型  号: IX910GMLE-C6
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel® Celerom® M 900MHz
w/512K L2 Cache
FSB
400MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel® 82910GMLE GMCH/82801FBM ICH6-M
I/O Chip
Winbond W83627EHG-A
System Memory
Two 240-pin DIMM socket supports up to 2 GB
DDR2 400 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature and cooling fan status.
Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant) supports
3 PCI master
S3
S3 Support
SmartFan Control
Speed Cruise Mode
I/O
MIO
1 xEIDE (Ultra DMA 100), 2 x SATA, 4 x RS-232, 1 x K/B, 1 x Mouse
IrDA
115k bps, IrDA 1.0 compliant
USB
8 x USB 2.0
DIO
16-bit General Purpose I/O for DI and DO
Display
Chipset
Intel® 82910GMLE GMCH integrated Graphics Media Accelerator 900
Display Memory
Intel® DVMT 3.0 supports up to 128 MB
video memory
Resolution
2048 x 1536 @ 32 bpp (85 Hz)
Dual Display
CRT + LVDS, or CRT + DVI-D
LVDS
Intel® 910GMLE supports Single channel
18-bit / Dual-channel 36-bit LVDS
DVI
Chrontel CH7307C DVI transmitter up to
165M pixels/second
Audio
Chipset
Intel® 82801FBM ICH6-M
Audio Code
Realtek ALC655 supports 5.1 CH Audio
Audio Interface
Mic in, Line in, Line out
Audio Amplifer
TPA3005D2 Stereo 5 Watt per channel
Ethernet
LAN1
Realtek RTL8110SC PCI-E 1000Base-T
Gigabit Ethernet Controller
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 2 x RS-232
* 1 x VGA port
* 1 x DVI por
* 4 x USB 2.0/1.1
* 1 x RJ45 Port
* 5.1 CH Audio I/O (3 jacks)
Internal I/O Connector
* 2 x USB connectors support 4 USB ports
* 1 x 20-pin ATX Power connector
* 1 x IDE 40-pin connector for two devices
* 2 x COM port header
* 2 x SATA connectors
* 1 x Front panel audio connector
Mechanical & EnvironmentalI
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX910GMLE0C6
Intel® Celeron® M Mini ITX Motherboard with DVI/VGA, LVDS, Ampleified Audio, Giga LAN, 4 COM, 8 USB 2.0,
16-bit GPIO, 1 PCI & CF
关 键 词: 嵌入式 主板 IX910GMLE-C6
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
