产品介绍
IPPC-1580T 是一款无风扇设计平板电脑,主要用于无噪声工作环境和无尘室应用。IPPC-1580T 带有两套电源,一套为可选电池组,另外一套为交流电源。当IPPC-1580T 连接到交流电源时,系统会对内部的电池进行充电。可选的充电电池组能够提供超过 60 分钟的电池寿命,还可以在交流电源出现故障时起到 UPS 的功能。IPPC-1580T 安装孔符合 VESA 标准,可采用多种方式进行安装。
产品规格
CPU Embedded Intel ULV Celeron 1.0 GHz/ Embedded Intel Pentium M 1.1 GHz
Chipset Intel 852GM/ICH4 /Intel 855GME/ICH
Memory 2x200-pin SO-DIMM sockets, supporting DDR200/266 modules for up to 2 GB
BIOS AWARD® 4 Mbit Flash BIOS
SSD Supports Compact Flash card type I/II
LCD Display 15" TFT 1024*768 XGA LCD
Touch screen (Optional) Standard is built-in vandal proof infrared
HDD 1 x internal 2.5" IDE interface
I/O Ports
-3 x serial: 2 x RS-232, 1 x RS-232/422/485 (COM2)
- 4 x USB 2.0 ports: 2 x external, 2 x internal
-1 x PS/2 mouse and keyboard port
-1 x VGA port, 1 x Parallel port
-2 x built-in speakers (1 W each)
-2 x type II PCMCIA ports
-Line-in, Line-out & Mic-inport -Bus Expansion 1 x Mini PCI socket and 1 x 32-bit PCI expansion kit (optional)
COMBO Drive Optional DVD/CD-RW 8D/24W/24E/24R or above
Ethernet Speed 10/100 Mbps; 10/100/1000 Mbps (optional)
Power Support DC to DC Converter Input voltage: 18 ~ 25 VDC
AC to DC Converter -Input Voltage: 100 ~ 240 VAC @ 50 ~ 60 Hz
-Output Voltage:19V@4.73A
Operating Temperature 0 ~ 45° C (32 ~ 113° F)
Weight 7.2 kg
Environmental Specifications
Relative Humidity 10 ~ 95% @ 40° C, non-condensing
Shock 10 G peak acceleration (11 ms duration)
