| 系统 |
| CPU Support |
Intel Core / Celeron M processor |
| CPU Frequency |
1.46~2.23 GHz |
| Chipset |
Intel 945GM + ICH7 (FSB : 533/667MHz) |
| DRAM |
2 x 200-pin DDR2 DIMM, support DDR II 667 SDRAM up to 2GB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
1~255 secs Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT / ATX power |
| Power Requirement |
+5V, +12V |
| I/O 界面 |
| IDE Interface |
1 x 44-pin IDE (UDMA 33/66/100) |
| CF |
1 |
| FDD Interface |
One FDD connector with 34-pin Boxheader on board |
| Function BUS |
1 x PCI-E (16x) slots (SDVO), Mini PCI |
| Serial Port |
4 x COM ports, COM1/3/4 for RS232, COM2 for RS232/422/485 ( for 16550 compatible type of UART) |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector |
| Mouse |
| LAN |
LAN 1: Intel 82573V (10/100/1000 Mbps) Support Wake-on-LAN wtih ATX power |
| Audio |
AC 97 Codec, Realtek ALC655 With Line-in / Line-out / MIC |
| USB |
6 x USB 2.0 |
| 显示 |
| Graphics |
Built-in Intel 945GM, share system memory, Support CRT, LVDS, SDVO, TV |
| LCD Interface |
18-bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
