| 系统 |
| CPU Support |
Intel Pentium M / Celeron M processor |
| CPU Frequency |
ULV 1GHz / LV 1.4GHz |
| Chipset |
Intel 855GME + ICH4 (FSB: 400MHz) |
| DRAM |
1 x 200-pin DDR SO-DIMM, support DDR266 SDRAM up to 1GB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
1~255 secs Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT power |
| Power Requirement |
+5V, +12V (Only +5V) (Only +5V : +5V only provide power for SBC, dont have enough power to support |
| Power Consumption |
Only +5V : 3.72A / +5V : 3.65A / +12V : 0.044A |
| Dimension |
102mm x 145mm ( 4.02" x 5.71" ) |
| I/O 界面 |
| IDE Interface |
1 x 44-pin IDE ( UDMA 33 ) |
| Bus Interface |
PC / 104+ |
| Serial Port |
2 x COM ports, COM1 for RS232, COM2 for RS232/422/485 ( for 16550 compatible type of UART) |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector or external connector |
| Mouse |
Y-cable |
| LAN |
Intel 82562ET (10/100 Mbps) |
| Audio |
AC 97 Codec, Realtek ALC202A With Line-in / Line-out / MI |
| USB |
2 x USB2.0 |
| 显示 |
| Graphics |
Built-in Intel 852GM, share system memory, support CRT, LVDS, TV-OUT |
| LCD Interface |
18 / 36 - bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
