12.1”Industrial Fanless Touch Panel Computer
| Fanless and AMD LX-800 500MHz processor |
| 12.1" SVGA (800x600) color TFT LCD |
| One 200-pin SO-DIMM DDR 266/333MHz, up to 1GB |
| NEMA 4/IP 65 compliant front panel |
| Sealed resistive touch screen |
| Support Panel / VESA 75 mount |
| DC 11~28V wide-range power input | |
| 显示规格 |
| 显示 |
12.1" SVGA TFT LCD |
| 亮度 |
300 cd/m2 |
| 视角 |
120/95 (R/L) |
| 分辨率 |
800 x 600 |
| 背光 |
50,000 hrs |
| 系统与结构 |
| 架构 |
Plastic front panel & metal housing |
| 前面板颜色 |
黑色 |
| CPU |
AMD LX-800 500MHz |
| DRAM |
1 x 200-pin SO-DIMM DDR 266/333MHz, up to 1GB |
| 存储 |
Space for 2.5” HDD and 1 CF card slot, or 1 Compact Flash card slot |
| 电源 |
DC 11~28V |
| 触摸屏 |
Analog resistive |
I/O 控制 |
4 x COM ports (COM1, COM3:RS-232, COM2:RS-232/422/485, COM4:reserved for touch screen),2 x USB 2.0, 2x5 2.0mm pin header for internal USB 2.0 x 2, 1 x PS/2 keyboard & mouse, on board Buzzer x 1, 1 x Reset switch,1 x LAN port, 1 x power on/off switch, 1 x AC97 Codec, Line-in, Line-out, Mic, 2 x SATA port (optional),1 x VGA port |
| 尺寸 |
317(W)x243(H)x62(D)mm |
| 重量 |
4.3kgs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 60 ℃ |
| 储存湿度 |
10 - 90% @40 ℃, non-condensing |
| 振动 |
5~500Hz (Random), 1G acceleration peak to peak |
| 冲击 |
15G acceleration peak to peak (11msec |
| 面板防护 |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
| OS 兼容性 |
Windows CE net 4.2 / 5.0, XP, XP Embedded |
