| 系统 |
| CPU Support |
Intel Celeron M processor |
| CPU Frequency |
ULV 600MHz (non L2 cache) |
| Chipset |
Intel 852GME + ICH 4 |
| DRAM |
2 x 184-pin DDR DIMM, support DDR266 SDRAM up to 2GB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
1 ~ 255 secs Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT/ATX power |
| Power Requirement |
+5V, +12V, -12V |
| Power Consumption |
+5V: 3.34A +12V : 0.56A |
| Dimension |
203mm x 146mm ( 7.99" x 5.75" ) |
| I/O 界面 |
| IDE Interface |
1 x 40-pin IDE ( UDMA 33/66/100 ), 1 x 44-pin IDE ( UDMA 33/66/100 ) |
| CF |
1 x compact flash slot ( IDE ) |
| FDD Interface |
1 |
| Bus Interface |
PCI slot, EPCI BUS |
| Serial Port |
4 x COM ports, COM1 / 3 / 4 for RS232, COM2 for RS232 / 422 / 485 ( for 16550 compatible type of UART ) |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR ) |
| Keyboard |
4-pin header with mini DIN cable |
| Mouse |
| LAN |
Intel 82562EM ( 10 / 100 Mbps ), Support Wake-on LAN with ATX power |
| Audio |
AC 97 Codec, Realtek ALC202A with Line-in / Line-out / MIC |
| USB |
4 x USB2.0 |
| 显示 |
| Graphics |
Built-in Intel 852GME, shared system memory, Support CRT & LVDS |
| LCD Interface |
18 /36 - bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
