| 系统 |
| CPU Support |
VIA Mark Processor |
| CPU Frequency |
533/800 MHz |
| Chipset |
Mark + VT82C686B(FSB : 133MHz) |
| DRAM |
1 x 168-pin DIMM, support PC100/133 SDRAM up to 512MB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
16 level Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT/ATX power |
| Power Requirement |
+5V, +12V, -12V (Only +5V with 4.8W power module) (Note : power module does not have enough power to support any add-on cards.) |
| Power Consumption |
+5V : 3A / +12V : 0.17A (VIA Eden 800MHz) +5V : 2.5A / +12V : 0.14A (VIA Eden 400MHz) |
| Dimension |
203mm x 146mm (7.99" x 5.75") |
| I/O 界面 |
| IDE Interface |
1 x 40-pin IDE (UDMA 33/66/100) 1 x 44-pin IDE (UDMA 33/66/100) |
| CF |
1 x compact flash slot (IDE) |
| FDD Interface |
1 |
| Bus Interface |
PCI slot, PC/104, PC/104+ |
| Serial Port |
4 x COM ports, COM1/3/4 for RS232, COM2 for RS232/422/485 ( for 16550 compatible type of UART) |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR ) |
| Keyboard |
4-pin header with mini DIN cable |
| Mouse |
| LAN |
LAN 1 : Realtek RTL8110S (10/100/1000Mbps) LAN 2 : Realtek RTL8110S (10/100/1000Mbps) Support Wake-on-LAN wtih ATX power |
| Audio |
AC 97 Codec, Realtek ALC201A with Line-in / Line-out / MIC |
| USB |
4 x USB1.1 |
| 显示 |
| Graphics |
Built-in VIA Mark, share system memory, Support CRT, TTL & LVDS |
| LCD Interface |
18/24-bit TTL, 18/36-bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
