| 系统 |
| CPU Support |
Intel Celeron D, Pentium 4, Pentium D, Core 2 Duo, LGA-775 processor |
| Chipset |
Intel Q965 + ICH8DO + FWH (FSB:533/667/800/1066MHz) |
| DRAM |
2 x 240-Pin DDR2-DIMM Socket (Support 4GB) |
| BIOS |
PhoenixAward PnP BIOS, with VGA BIOS |
| Watchdog |
1~255 secs Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support ATX / AT Power |
| Power Requirement |
+5V, +12V |
| Power Consumption |
+5V : 3.2A / +12V : 10.45A |
| Dimension |
338.5mm x 122mm ( 13.33" x 4.8" ) |
| I/O 界面 |
| IDE Interface |
1 x 40-pin IDE (UDMA33/66/100) |
| SATA Interface |
4 x S-ATA connector |
| FDD Interface |
One FDD connector with 34-pin Boxheader on board |
| Bus Interface |
CF x 1 , MXM bus |
| Serial Port |
2 port, 16550 UARTs RS-232 x COM1 for RS-232, COM2 for RS-232/422/485 |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector |
| Mouse |
| LAN |
Lan1:Marvell 88E8052, 1G BaseTx Ethernet Lan2:Marvell 88E8052, 1G BaseTx Ethernet
Lan1:Marvell 88E8052, 1G BaseTx Ethernet Lan2:Marvell 88E8052, 1G BaseTx Ethernet |
| Audio |
Realtek ALC262 with Line-in / Line-out / MIC |
| USB |
4 x USB2.0 |
| 显示 |
| Graphics |
Built-in Intel Q965, share system memory, Support CRT |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
