产品介绍: |
| 10.4” Industrial Fanless Touch Panel Computer |
| 板载Celeron M 1GHz up to 1.5G 处理器 |
| DC 11~28V wide-range power input |
| Support Panel / VESA 75 mount |
| 显示规格 |
| 显示 |
10.4" SVGA TFT LCD |
| 亮度 |
250 cd/m2 |
| 视角 |
120°(R/L) , 110° (U/D) |
| 分辨率 |
800 x 600 & 262K |
| 背光 |
20,000 hours |
| 系统与结构 |
| 架构 |
紧凑型塑料面框超薄设计 |
| 前面板颜色 |
黑色 |
| CPU |
Celeron M 1GHz up to 1.5GHz |
| 存储 |
256MB SDRAM up to 1GB |
存储设备 |
Space for 2.5" HDD and 1 CF card slot, or 1 Compact Flash card slot |
电源 |
DC 11~28V |
触摸屏 |
I/O 控制 |
2 x COM port (COM1: RS-232, COM2: RS-232/422/485) 2 x USB 2.0 , 1 x PS/2 keyboard & mouse 1 x Ethernet port (10/100/1000base-T) 1 x AC97 Codec, Line-in, Line-out, Mic, VGA port 1 x parallel port |
| 尺寸 |
317(W) x 74(D) x 243mm(H) |
| 重量 |
4.3kg/9.48 lbs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 60 ℃ |
| 储存湿度 |
10 - 90% @50 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10 to 25Hz (X,Y,Z direction 2G, 30 minutes) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
上架式面板安装 / VESA 75支架安装 | |
| 型号 |
描述 |
| AHM-6105 |
10.4" Fanless Touch Panel Computer w/Resistive Touch Screen | | |
