| 系统 |
| CPU Support |
Intel Pentium M / Celeron M processor |
| CPU Frequency |
1.3~2.06 GHz |
| Chipset |
Intel 915GM + ICH6M (FSB: 400/533MHz) |
| DRAM |
2 x 200-pin DDR So-DIMM, support DDR2 533 SDRAM up to 2GB |
| BIOS |
Phoenix-Award PnP BIOS, with VGA BIOS |
| Watchdog |
1~255 secs Watchdog timer selectable w / Reset / NMI |
| Power Supply |
Support AT/ATX power |
| Power Requirement |
+5V, +12V, -12V |
| Power Consumption |
+5V : 3.69A / +12V : 2.37A (Pentium M 1.8GHz) |
| Dimension |
338.5mm x 122mm ( 13.33" x 4.8" ) |
| I/O 界面 |
| IDE Interface |
1 x 40-pin IDE (UDMA 33/66/100) |
| CF |
1 x compact flash slot ( IDE ) |
| FDD Interface |
1 |
| Bus Interface |
EPCI BUS |
| Serial Port |
2 x COM ports, COM1 for RS232,COM2 for RS232/422/485 ( for 16550 compatible type of UART) |
| Parallel Port |
1 x parallel (SPP / EPP / ECP) |
| IrDA |
1 ( SIR ) |
| Keyboard |
Mini DIN connector or external connector |
| Mouse |
Mini DIN connector ( selectable w/KB ) or Y-cable |
| LAN |
LAN 1: Marvell 8052 (10/100/1000 Mbps) LAN 2: Marvell 8052 (10/100/1000 Mbps) Support Wake-on-LAN wtih ATX power |
| Audio |
AC 97 Codec, Realtek ALC201A with Line-in / Line-out / MIC |
| USB |
6 x USB2.0 |
| S-ATA Interface |
2 |
| Digital I/O |
8-in/8-out |
| 显示 |
| Graphics |
Built-in Intel 915GM, share system memory, support CRT, LVDS, DVI |
| LCD Interface |
18/36 - bit LVDS |
| 环境 |
| Operating Temp. |
0 ~ 60 C ( 32 ~ 140 F) |
| Storage Temp. |
-40 ~ 85 C ( -40 ~ 185 F ) |
| Humidity |
Operation humidity 20 ~ 90%, storage humidity 20 ~ 95% |
