| 产品名称: |
品富 人机界面AHM-6104
| 型 号: |
AHM-6104 |
| 价 格: |
| 品 牌: |
产品介绍: |
| 10.4”Industrial Fanless Touch Panel Computer |
| 10.4" TFT LCD supports 800 x 600 resolution |
| 板载VIA Eden 400MHz /733MHz 处理器 |
| Support Panel / VESA 75 mount |
| 显示规格 |
| 显示 |
10.4" SVGA TFT LCD |
| 亮度 |
250 cd/m2 |
| 视角 |
120° (R/L) 110° (U/D) |
| 分辨率 |
800 x 600 |
| 背光 |
20,000 hours |
| 系统与结构 |
| 架构 |
紧凑型塑料面框超薄设计 |
| 前面板颜色 |
黑色 |
| CPU |
VIA Eden 400MHz /733MHz |
| 存储 |
256MB SDRAM up to 512MB |
存储设备 |
1 Compact Flash card slot, or space for 2.5" HDD and 1 CF card slot |
电源 |
AC 100~240V |
触摸屏 |
I/O 控制 |
2 x Serial ports (COM1: RS-232, COM 2:RS-232 /422/485) 1 x Ethernet port (10/100 base-T), 2 x USB 1.1 1 x parallel port, 1 x Stereo audio Mic-in, Line-in and Line-out; 1 x PS/2 keyboard & mouse |
| 尺寸 |
317(W) x 74(D) x 243(H) mm |
| 重量 |
4.3kgs/ 9.48lbs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
0 - 60 ℃ |
| 储存湿度 |
10 ~ 95% @40 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10G acceleration peak to peak (11ms) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
上架式面板安装 | |
| 型号 |
描述 |
AHM-6104 AHM-6104-01 AHM-6104-02 AHM-6104-04 AHM-6104-05 AHM-6104-06 AHM-6104-08 |
10.4" VGA TFT Eden 400 HMI barebone w/resistive touch 10.4" VGA TFT Eden 400 HMI w/resistive touch, 128MB DRAM 10.4" VGA TFT Eden 400 HMI w/resistive touch, 256MB DRAM 10.4" VGA TFT Eden 733HMI barebone w/resistive touch 10.4" VGA TFT Eden 733HMI w/resistive touch, 128MB DRAM 10.4" VGA TFT Eden 733HMI w/resistive touch, 256MB DRAM 10.4" VGA TFT Eden 400HMI barebone 12/24V DC input w/resistive touch | | |
| 关 键 词: |
APLEX 人机界面 AHM-6104 |
