产品名称: PSB-701LF工业主板
型  号: PSB-701LF
PICMG 1.3 full size card suppot Core 2 Quad CPU
Features:
Support Intel Core 2 Quad, Intel Core 2 Duo, Intel Celeron M
Support Trusted Platform Module
Memory Supports DDRII 800 SDRAM up to 4GB
Equipped with Intel Q35 Chipset with FSB 1333MHz
Applications such as factory automation, finance, telecommunication, security, storage, multimedia and more
Specifications:
系统
CPU Support Intel Core 2 Quad/ Core 2 Duo/ Celeron CPU with LGA775 CPU socket. (support Intel 65nm, 45nm Process Technology CPU)
CPU Frequency Core 2 Quad: 2.4~2.66GHz / Core 2 Duo: 1.8~3.0GHz /
Chipset Intel Q35 + ICH9DO (FSB: 800/1066/1333MHz)
DRAM 2 × 240-Pin DDR2 DIMM, supports Dual channel memory architecture and DDR2 667/800MHz up to 4GB
BIOS Phoenix-Award PnP BIOS, with 32MB SPI flash
Watchdog 1~255 secs Watchdog timer selectable w/Reset/NMI
Power Supply Support ATX power
Power Consumption +5V:3.3A, +12V:5.63A, +3.3V:1.64A, 5VSB:0.26A (USE INTEL CORE 2 QUAD Q6700 2.66GHz)
Power Requirement +5V, +12V, +3.3V, +5Vsb (from Backplane)
Dimension 338.5 mm x 126 mm (13.33" x 4.96")
Certificate FCC / CE
I/O 界面
SATA Interface 4 x S-ATA II connector (Raid 0,1,10,5)
TPM TPM1.2 1 with 20-pin header on board for TPM (Trusted Platfom Module)
Serial Port 2 x COM port, COM 1 for RS232, COM 2 for RS232/422/485 ( for 16550 compatible type of UART)
Keyboard Mini DIN connector or external connector
Mouse Mini DIN connector or external connector
LAN LAN 1: Intel 82566DM (10/100/1000 Mbps)
Support Wake-on-LAN wtih ATX power
Audio High High Definition Audio
USB 6 x USB 2.0
显示
Graphics Built-in IntelR Q35, share system memory
LCD Interface 18/24-bit LVDS
环境
Operating Temp. 0°~60°C(32°~140°F)
Storage Temp. -40°~85°C(-40°~185°F)
Humidity Operation Humidity 20~90%, Storage Humidity 20~95%
Ordering Information:
Order No Description
关 键 词: 工业主板 APLEX
公司名称: 品富电子科技上海有限公司
联 系 人: 孔哲人
电  话: 021-54262303
手  机:
地  址: 上海市桂平路470号14号搂5层B区
邮  编: 200233
整机IP67全防水平板电(IP67)
APC-3081 人机(APC-3081)
品富AIX-503 MI(AIX-503)
品富AIX-510 MI(AIX-510)
APC-3716嵌入式平(APC-3716)
APC-3916嵌入式平(APC-3916)
APC-3516嵌入式平(APC-3516)
APC-3517嵌入式平(APC-3517)
APC-3717嵌入式平(APC-3717)
APC-3927嵌入式平(APC-3927)
APC-3262A嵌入式(APC-3262A)
APC-3562A嵌入式(APC-3562A)
AHM-6053 人机界(AHM-6053)
AHM-6127 NEW(AHM-6127 NEW)
AHM-6057 人机界(AHM-6057)
品富 AHM-6087 (AHM-6087)
品富 AHM-6107 (AHM-6107)
品富 AHM-6058 (AHM-6058)
品富 AHM-6108 (AHM-6108)
品富 AHM-6128 (AHM-6128)
