产品介绍: |
| 15”RISC-based Human Machine Interface |
| 板载无风扇低功耗Intel Xscale PXA255处理器 |
| Onboard with DRAM, Flash and SRAM memory bank |
| USB 1.1 host and 1.1 client supported |
| 1个10/100兆高速以太网口 |
| 紧凑型塑料面框超薄设计 |
| DC 11~28V wide-range power input |
| 显示规格 |
| 显示 |
15" XGA TFT LCD |
| 亮度 |
350 cd/m2 |
| 视角 |
150° (R/L) 125° (U/D) |
| 分辨率 |
1024x768 |
| 背光 |
50,000 hrs |
| 系统与结构 |
| 架构 |
紧凑型塑料面框超薄设计 |
| 前面板颜色 |
黑色 |
| CPU |
Intel Xscale PXA255,400MHz |
| 存储 |
128MB DRAM, 1MB SRAM with battery backup, 32MB Flash for operating system CF slot for application software |
| 电源 |
DC 11~28V |
触摸屏 |
4线式电阻式触摸屏 |
I/O 控制 |
COM1 (RS-232/422/485) COM2 (RS-232) PS/2 port: 1 x keyboard, 1 x mouse , USB Client 1.1 and Host 1.1 Ethernet port , 1 x CF slot,Speaker out x 1 / Min-in x 1, External VGA port |
| 尺寸 |
409(W) x 56(D) x 309mm(H) |
| 重量 |
7.18 kgs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 60 ℃ |
| 储存湿度 |
10 ~ 90% @50 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10 to 25Hz (X,Y,Z direction 2G, 30 minutes) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
上架式面板安装 / VESA 75支架安装 |
| OS 兼容性 |
Windows CE 4.2 / 5.0 | |
| 型号 |
描述 |
| AHM-6151 |
15" RISC-based Human Machine Interface w/resistive touch screen | | |
