| 产品名称: |
AWK-4630 8U一体化工作站
| 型 号: |
AWK-4630 |
| 价 格: |
| 品 牌: |
产品介绍: |
| 8U/15" w/10-slot Industrial Workstation |
| 15" high brightness TFT LCD (400 cd/m2) |
| Heavy-duty rack-mount steel enclosure |
| Lockable door provides protection for unauthorized download data |
| Built in with P4 based full-size industrial-grade single board |
NEMA-4/IP-65 rated aluminum alloy front panel with built-in membrane keypad, touch pad, USB ports and Floppy/CD-ROM driver | |
| System |
| Front Panel |
Aluminum, meets NEMA-4/IP-65 |
| Membrane keypad |
59 Numeral/Character keys 12 function keys 4 OSD control keys 2 touch pad buttons |
| Keyboard |
USB interface for membrane keypad and touch pad PS/2 interface for external keyboard |
| Drive bays |
Front access to one 3.5" HDD, FDD and 5.25" CD-ROM with dust-protection door |
| Cooling system |
1 x 85 CFM fan (12cm) |
| Backplane |
10-slot full-size |
| Touch screen(optional) |
Analog resistive type with RS-232 controller |
| Display |
| LCD |
15" TFT LCD (1024 x 768) |
| Resolution |
2048 x 2048 |
| Brightness |
400 cd/m2 |
| Backlight |
Lifespan of 50,000 hours |
| Interface |
Analog VGA input with OSD |
| Mechanical |
| Painted Color |
White (Pantone 413C) |
| Dimensions |
483 (W) x 354 (H) x 266 (D) mm |
| Weight |
16kg |
| Environment |
| Operating Temp. |
0 ~ 50 |
| Storage Temp. |
-10 ~ 75 |
| Relative humibity |
5 ~ 95%, non-condensing |
| Vibration |
5 ~ 17Hz, 0.1 double amplitude displacement 17 ~ 500Hz 1.5G peak to peak |
| Shock |
10G acceleration peak to peak (11 millimeters) |
| EMC |
FCC/CE Class A certified |
| Order No |
Description |
AWK-4630-02 AWK-4630-03
Option |
8U/15" XGA TFT Industrial Workstation w/300W PSU and 10-slot B/P 8U/15" XGA TFT Industrial Workstation w/300W PSU, 10-slot B/P & PSB-1720 SBC Resistive touch screen | | |
| 关 键 词: |
工业一体化工作站 APLEX |
