| Structure |
| Construction |
Fine steel chassis |
| Color |
Black front panel |
| Dimensions |
483 (W) x 174 (H) x 312mm (D) |
| Weight |
11kg |
| Drive Bays |
| 1 x 5.25-inch CD-ROM (Placed in front) |
| 1 x 3.5-inch FDD (Placed in front) |
| Vibration-proof and impact-proof |
| I/O Connection |
| Front Access |
| Cooling Fan |
| Size |
2 x 9cm fan |
| CFM |
38 x 2 CFM |
| Air filter |
Can be replaced |
| Multi Functions |
| LCD |
8-inch TFT LCD with resolution of 800 x 600 and luminance of 400cd/m2 |
| Keyboard |
Super thin, 88 keys |
| Board control |
Power switch, reset button |
| Board indicator |
Power indicator light, hard disk indicator light |
| Touch screen |
A standard PS/2 - compatible touch pad with two mouse-like buttons |
| Environment |
| Operating Temp. |
0 ~ 50 |
| Storage Temp. |
-10 ~ 75 |
| Vibration |
5 ~ 17Hz, 0.1" double amplitude displacement 17 ~ 640Hz, 1.5G acceleration |
| Impact |
10G acceleration peak to peak (11 millimeters) |
| EMC |
FCC/CE Class A certified |
