产品介绍: |
| 10.4” RISC-based Human Machine Interface |
| 10.4" TFT LCD with resolution of 800x600 |
| 板载无风扇Intel Xscale PXA255处理器 |
| SMI SM501芯片支持双显示 |
| DC 11~28V wide-range power input |
| 1个CompactFlash Type I/II插槽 |
| 显示规格 |
| 显示 |
10.4"SVGA TFT LCD |
| 亮度 |
250 cd/m2 |
| 视角 |
130° (R/L) 110° (U/D) |
| 分辨率 |
800 x 600 |
| 背光 |
20,000 hrs |
| 系统与结构 |
| 架构 |
紧凑型塑料面框超薄设计 |
| 前面板颜色 |
黑色 |
| CPU |
Intel Xscale PXA255,400MHz |
| 存储 |
128MB DRAM 1MB SRAM with battery backup 32MB Flash for operating system CF slot for application software |
| 电源 |
DC 11-28V |
触摸屏 |
4线式电阻式触摸屏 |
I/O 控制 |
COM1(RS-232/422/485), COM2(RS-232/) PS/2 port for keyboard or mouse USB Client 1.1 and Host 1.1, Ethernet port External VGA port, Speaker out x 1/Mic-in x 1 CF slot |
| 尺寸 |
317(W) x 50(D) x 243mm(H) |
| 重量 |
4.3kg/9.48 lbs |
| 环境规格 |
| 工作温度 |
0 - 50 ℃ |
| 储存温度 |
-20 - 60 ℃ |
| 储存湿度 |
10 ~ 95% @50 无冷凝 |
| 振动 |
5 - 17Hz, 0.1" double amplitude displacement 17 - 640Hz, 1.5G acceleration peak to peak |
| 冲击 |
10 to 25Hz (X,Y,Z direction 2G, 30 minutes) |
| 面板防护 |
NEMA 4/IP 65 compliant front panel |
| 认证 |
Meet CE / FCC Class A |
| 安装方式 |
上架式面板安装 / VESA 75支架安装 |
| OS 兼容性 |
Windows CE 4.2 / 5.0 | |
| 型号 |
描述 |
| AHM-6101 |
10.4" RISC-based Human Machine Interface w/resistive touch screen | | |
