产品介绍: |
| 无风扇平板电脑,板载超低电压Intel Celeron M 处理器,带12" TFT LCD及2个扩展槽 |
| 无风扇设计,1 x以太网(10/100 BASE-TX RJ45界面) |
| 2 PCI expansion slots, 2 x USB 2.0 ports |
| DC 11~28V wide-range power input |
| 可安装1个防震2.5" HDD 支架,1个超薄FDD和1个超薄 CD-ROM(可选) | |
| 系统规格 |
| CPU |
板载超低电压Intel® Celeron® M ULV 600MHz (non L2 cache)处理器 |
| 芯片组 |
Intel® 852GM + ICH 4 |
| 存储 |
up to 1GB DDR SDRAM |
| 内存插槽 |
1 x 200-pin SO-DIMM |
| 驱动磁盘架 |
1 x 防震2.5" HDD ,1x slim CD/DVD/Combo drive(可选) |
| BIOS |
Phoenix-Award 2MB PnP BIOS |
| IDE Interface |
UDMA 33 / 66 / 100 x 2 |
| 触摸屏(可选) |
电阻式 |
| I / O 控制 |
4 x COM ports, 1 x Parallel port, 1 x PS/2 keyboard and mouse ports, 6 x USB 2.0 (4 by pin header), 1x LAN, 1 x VGA, 1 x DVI, 1xAudio Mic, Line-in, Line-out |
| 扩展槽 |
2 x PCI Slots |
| 无风扇/风扇 |
无风扇架构 |
| 显示规格 |
| 显示 |
12.1" SVGA |
| 分辨率 |
800x600 |
| 亮度 |
300 cd/m2 |
| 背光 |
50,000 hrs |
| 结构与环境 |
| 构造 |
强固型钢外壳,前面板获得IP-65认证 |
| 前面板颜色 |
浅灰色 |
| 电源 |
DC 11~28V |
| 工作温度 |
0 ~ 50 |
| 储存温度 |
-10 - 75 |
| 振动 |
5 - 17 Hz, 0.1" double amplitude displacement, 17 - 640 Hz, 1.5G acceleration peak to peak |
| 冲击 |
10G 峰值加速度 (持续时间11ms) |
| EMC认证 |
Meet CE / FCC Class A |
| 安装方式 |
平板安装 |
| 尺寸 |
390(W) x 264(H) x 102(D)mm |
| 重量 |
6.45kgs |
| 型号 |
描述 |
APC-3262
APC-3262-T
APC-3262-S
APC-3262-ST |
Barebone with Celeron M 600MHz processor w/o touch, HDD, RAM and CD-ROM. Barebone with Celeron M 600MHz processor & resistive touch screen w/o HDD, RAM and CD-ROM Celeron M 600MHz processor, 256MB DDR SO-DIMM, 40GB HDD, slim combo DVD w/o touch
Celeron M 600MHz processor, resistive touch screen, 256MB DDR SO_DIMM, 40GB HDD, slim combo DVD | |
