产品介绍: |
| 19" SXGA Industrial Display Monitor |
| 1280(H) x 1024(V), 300 cd/m2 |
| Front Panel NEMA 4/IP 65 rating |
| Resistive touch screen (optional) |
| OSD control on the front side |
| Optional DVI, Video and S-Video input |
| Optional Aluminum front bezel |
| Support Panel / VESA 75 mount |
Support wide-ranging resolutions from 640x480 to up to 1600 x 1200 with auto phase and auto position |
| AC 100~240V, optional DC 11~28V power input | |
| 显示规格 |
| 显示 |
19" SXGA color Active TFT Flat Panel dislay |
| 亮度 |
300 cd/m2 |
| 视角 |
160/160 °(H/V) |
| 分辨率 |
1280 x 1024 (native mode), 16.7M colors |
| 背光 |
50,000 hrs |
| 触摸屏 |
Analog resistive (optional) |
| OSD 控制 |
On the front side |
| 电源 |
AC 100~240V, optional DC 11~28V |
| I/O 控制 |
1xAC power input, 1xVGA, optional: DVI, S-Video, RCA, touch (RS-232 or USB) |
| 结果规格 |
| 架构 |
Steel front bezel & steel chassis |
| 尺寸 |
467(W)x379(H)x 64.7(D)mm |
| 安装 |
| 环境规格 |
| 工作温度 |
0 - 45 ℃ (32 - 113 ℉) |
| 储存温度 |
-20 - 60 ℃ (-4 ~ 140 ℉) |
| 储存湿度 |
10 - 95% @40℃ Non-condensing, without touch screen |
| 振动 |
1G peak, 10-150 Hz (Random) |
| 冲击 |
15G peak acceleration (11 msec, duration) |
| 面板防护 |
NEMA 4/IP 65 compliant front bezel |
| 认证 |
Meet CE / FCC Class A |
| Order No |
Description |
| Optional |
Aluminum front bezel & steel chassis | | |
