测试电流 |
AC 3A ~ 32A |
测试电压 |
最大 8V AC Typically |
量测阻抗范围 |
0 to 0.12Ω, 0 to 0.6Ω共 2 档 |
量测准确度 |
3A ~ 5A, +10% 满刻度 5A ~ 32A, +5% 满刻度 |
电流表 |
显示测试电流及警告设限值 |
阻抗表 |
显示测试电阻及 Fail 与 SUBTRACTION 设定值 |
切换开关 |
Zero-start operating switch |
计时器 |
1S, 10S, 1MIN, 10MIN 共 4 档 |
警告 |
Monitor the variation test current, when the test current is beyond+10% of the setting value, the warning operation will proceed. 警告设定范围 3A ~ 32A |
SUBTRACTION |
The resistance of testing line can be subtracted from the test value The subtraction range from 0 ~ 0.1Ω 准确度 +10% |
GO-NOGO判定设定 |
If the test reading value is beyond the setting value, the fail will be acting, otherwise the pass will proceed. 设定值范围,为测试档位的 5% ~ 100% 准确度 +15% 满刻度 (3A ~ 5A);+10% 满刻度 (5A ~ 32A) |
远端控制 |
高电压输入 11V ~ 15V, 低电压 0 ~ 4V 及低电流输入 20mA 以下 |
测试模式 |
正常模式: 当警告声响起,测试停止 连续模式:当警告声响起,测试仍持续进行 |
蜂鸣器 |
当测试失败时,提供蜂鸣声 |
测试频率 |
50Hz 或 60Hz independent 视电源电压而定 |
输出信号 |
TEST, GO, NG, WARNING, READY, MONITOR |
使用电源 |
交流 100V/120V/220V/240V+10%, 50/60Hz |
附件 |
电源线 x 1, 操作手册 x 1, 测试线 GHT-115 x 1 |
This instrument is designed to test Grounding continuity resistance of the monitor, Switching power supplies, Power cord and Electronic appliances. |
