产品名称: 荷兰PRECIA-MOLEN称重传感器
型  号: CSP-M /0t
荷兰 PRECIA-MOLEN称重传感器
柱式称重传感器:
CSP-M :10t,25t,40t,60t,100t
SCL 35 t : 3 500 d (C3.5) and 2 x 3 500 d (C3.5MB)
SCL 35 t Ex : 3 500 d - C3.5
SCL 55 t : 3 500 d (C3.5) and 2 x 3 500 d (C3.5MB)
SCL 55 t Ex : 3 500 d - C3.5
ASL 30t: 3500 d (C3.5)
ASL 30 t Ex :3500 d C3.5
ASL 50 t :3000 d (C3)
ASL 30 t Ex :3000 d C3
波纹式称重传感器
FA3000 i 系列:   Accuracy class: D1、C3、C6
                  Capacities: 10-20-50-100-200-500 kg
剪切梁式:
CMA load cell:   CMA300、CMA500、CMA1000
CMI Load cell:    CMI500、CMI1000、CMI2000、CMI5000
S型称重传感器
TA-I 500、TA-I 100、TA-I 2000、TA-I 5000
Indicator:
I100、I100-S
I200B、I200M、I200B-S、I200M-S、I200B/I200M(-S)-D
I200EX
I300-S、I300
Controllers:
I400D-M、 I400D-MS 、I400TB 、I400TB-S、I400SDU 、I400WLC;
Process 12、Process13c/14c/T1c、Process 15、Process Satellite Dosing application、Process NUM SI : AFNSI、ISIA、ISIC;
Mascon-3 ABS ;
Siwarex FTA;
Printers:
 Alpha II、 TM 295、IBE 94 、LQ300  、P100  、P950  ;
(remote) Displays:
 D200 、ABC57  、ABC100/160/250  、RVO remote display (-0+ indicator) ;
Interfaces / adaptors:
 Profibus-DP 、Interbus-S 、 DeviceNet ;
固定称重:
Vehicle weighbridges fixed position :
VS-110 C/P 40 to 100t
VS-120 C/P 40 to 80t
VS-125 C/P 40 to 70t
VS-200 C(/P) 30 to 100t
VS-200 CS(/P) 30 to 100t
VS-200 S(/P) 30 to 100t
VS-300 CS 30 to 60t
VS-300 S 30 to 60t ;
Vehicle weighbridges Mobile versions :
VS-950 S/R 30 tot 60t
VS-920 S/R 30 tot 70t
ROC (pdf)
7ELEM (pdf)
Railway weighbridges WS-110;
Truck dumpers Weighing and non-weighing:
EVS-T weighing truck dumper
VS-T non-weighing truck dumper ;
Traffic controlFor weighbridges;
Weighbridge self-service units and terminals
For weighbridges and various other applications :
BI300 self service unit ;
Standard scales:
C 100 、C 200 B / C 200 M 、CK 100  、CR 100 、CR 100-S
CK 200  、CR 200 、CR 200-S ;
Mobile weighining instruments Multiple applications:
MCW Crane hook weigher
TPW Weighing pallet trucks
LTF / LTW Weighing forks / fork unit for lift trucks
WWS Axle weighers ;
Platform scales
For every industrial weighing need the right solution :
K range platform scales industrial use
R1 GM platform scales table top / floor use
Jet'FP P Pallet scale
R1 DL range platform scale table top use
R4 SB-S range Low profile platform scales
R4 range Industrial platform scale ;
Dynamic weighing :
ABS hopper scales
Bulk scales for weighing of bulk goods :
ABS-XL hopper scales, standard and ATEX
ABS-XL-SCS hopper scales, standard and ATEX
ABS-XT throughput weigher
Hopper scale automation / Process Control Software;
Check weighers
TLV dynamic check weighers ;
Bagging scales:
BMG / DPG + BMB 、BMC 、BMX 、BMN ;
Bagging lines
Robot Palletizers
Auxiliary equipment ;
Dynamic bulk weighing:
Belt weighers: Weighing frames and weighing controllers
Back to index belt weighers
Weighing frames
SINGLE
FX
TAB
BT
VP
MP ;
Weighing controllers:
ROL 470 (single scale)
ROL 460 (single scale)
ROL 400 (multiple scale  ;
Dynamic bulk dosing
Belt weighers: Dosing frames en dosing controllers:
Dosing frames
SB
XK
SBF
MD
PEP
Dosing controllers
REG 460 (single scale)
REG 400 (multiple scale)
PEP 400 (multiple scale)
关 键 词: PRECIA MOLEN 传感器
公司名称: 现代豪方科技(深圳)有限公司
联 系 人: 梁永生
电  话: 0755-26998437
手  机: 13189724065
地  址: 广东省深圳市南山区高新技术产业园高新中二道12号
邮  编: 518057
HE-3H电极式液位开关(HE-3H)
振动式料位开关传感器(HTM-930N)
Z6FD1-100KG(Z6FD1-100KG)
托利多MTB-5(G)高(MTB-5(G))
HBM称重传感器Z6FC(Z6FC3/50KG)
浮子式液位变送器(HT-100RS)
电子台秤WS300L-2
称重传感器Z6FD1/1(Z6FD1/100KG)
ZEMIC传感器L6H5(L6H5)
新西兰PT传感器LS(LPAX LS PT-7000)
ZEMIC传感器B8D(B8D)
HBM称重传感器(Z6FC3/100KG)
传感器C16AD1/20(C16AD1/30T)
SB系列(SB系列)
传感器TSC-100 S(TSC-100)
Mettler Tole(PB303-S/FACT)
传感器IL-150 IL( IL-250)
法国MASTERK传感器(FFX)
传感器SBD-10 SB(SBD-20)
