产品名称: Autonics奥托尼克斯计数器LE4S,LE4SA
型  号: LE4S,LE4SA
品  牌: 奥托尼克斯Autonics
● 控制时间范围 (AT8PS:0.05~10秒;AT8PM:0.05~10分)
● 通过简单操作设定时间,直读时间范围设定内容功能
● AC110、220V 50/60Hz DC24、48、100/110V
● 用途:电源短暂停电或停电时维持原有线路及重新起动。
本公司代理AUTONICS(奥托尼克斯) 全系列产品,型号齐全,价格低:高速计数器、光纤传感器、转速表、线速表、光电开关、接近开关、计时器、PID温控器、电压表、电流表,光电传感器,微型光电传感器,连接器、反射板,光纤,旋转编码器(绝对型)(增量型),LCD计数器,数显计时/计数器,预算计数器,模拟计时器,数显计时器,LCD计时器,插头,插座,LCD转速表,线速度表,显示单元,面板表,多用面板表等......
LCD计数器
LA7N-1,LA7N-2,LA7N-3,LA7N-4,LA7N-1R,LA7N-2R,LA7N-3R,LA7N-4R,LA7N-F,LA7N-FR:W48*H24MM
数显计数器
FS5B W48*H24MM
FS4A W48*H24MM 100-240VAC,12-24VDC INPUT NPN
数显计时计数器
单预设FX4S,FX4,FX6,FX4H
双预设FX4-2P*,FX6-2P*,FX4H-2P,FX4L-2P,FX6L-2P
显示专用FX4Y-I,FX6Y-I,FX5S-I,FX4-I,FX6-I,FX4H-I,FX4L-I,FX6L-I
FX4Y-1 W72*H36MM INPUT NPN
FX6Y-1
FX5S-1 W48*H48MM 100-240VAC,12-24VDC INPUT NPN
FX4S W48*H48MM INPUT NPN
FX4-1 W72*H72MM 100-240VAC,12-24VDC INPUT PNP
FX6-1 W72*H72MM INPUT PNP
FX4 W72*H72MM INPUT PNP
FX6 W72*H72MM INPUT PNP
FX4-2P W72*H72MM INPUT PNP
FX6-2P W72*H72MM INPUT PNP
FX4H-1 W48*H96MM 100-240VAC,12-24VDC INPUT PNP
FX4L-1 W48*H96MM INPUT PNP
FX4H-2P W48*H96MM INPUT PNP
FX4H W144*H72MM INPUT PNP
FX6L-1 W144*H72MM INPUT PNP
FX4L-2P W144*H72MM 100-240VAC,12-24VDC INPUT PNP
FX6L-2P W144*H72MM INPUT PNP
数显计时计数器
CT4S W48*H48MM INPUT NPN/PNP
CT4S-2P W48*H48MM INPUT NPN/PNP
CT6S-1 W48*H48MM INPUT NPN/PNP
CT6S W48*H48MM INPUT NPN/PNP
CT6S-2P W48*H48MM INPUT NPN/PNP
CT6-1 W72*h72MM 100-240VAC,24-60VDC INPUT NPN/PNP
CT6 W72*h72MM INPUT NPN/PNP
CT6-2P W72*h72MM INPUT NPN/PNP
模拟计时器
AT8AN 100-240VAC/24-240VDC(12DCV)24,48VAC,110.220VAC,12,24,48,100VDC 8PIN SOCKET
AT11DN 11PIN SOCKET
AT11EN 8PIN SOCKET
AT8SDN W48*H48mm 110,220VAC,24,48,100/110VDC 0.5SEC-100SEC
AT8PSN W48*H48mm 110,220VAC24,48,100/110VDC 0.5,1.5,10SEC
AT8PMN W48*H48mm 0.5,1.5,10 Min
ATE W48*H48mm 110/220VAC12,24VDC100, 220VAC12.24VDC 1s,3s,6s,10s,30s,60s,
3m,6m,10m,30m,60m,3h,6h,12h,24h
ATE-1,2 W48*H48mm
数显计时器
FS4E W48*H48mm 100-240VAC,12-24VDC
FS5E1 W48*H48mm
LCD计时器
LE3S W48*H48mm 100-240VAC,24-240VDC
LE3SA W48*H48mm 110,220VAC
LE3SB W48*H48mm
LE4S W48*H48mm 24-240VAC,24-240VDC
LE4SA W48*H48mm
LE7N-S,M,H,HR w48*H24mm
LE7N-SF,MF,HF,HFR w48*H24mm / input24-240VAC,6-240VDC
LE7D-2 W72*h72mm 100-240VDC MULTITYPE
关 键 词: 天津Autonics 计数器 LE4S LE4SA
公司名称: 天津迈特斯科技自动化有限公司
联 系 人: 刘慈
电  话: 022-87895130
手  机:
地  址: 天津市南开区科研西路2号
邮  编: 300192
天津Autonics计数(LA7N-3R,LA7N-4R)
LG 接触器(GMC-12)
LG变频器SV110IS(SV110IS5-4N)
LG变频器SV185IS(SV185IS5-4N)
天津奥托尼克斯计数器LE(LE7D-2)
天津LG变频器SV008(SV008IS5-4N)
天津AUTONICS(奥(BF3RX,BF4RP, BS5-K2M,T2M,L2M)
Autonics奥托尼克(FX4-I,FX6-I)
AUTONICS(奥托尼(pr12)
LG变频器SV022IS(SV022IS5-4N)
现货Q00JCPU三菱P(Q00JCPU)
LG变频器SV075IS(SV075IS5-4N)
天津Autonics计数(LA7N-F,LA7N-FR)
LG变频器SV055IS(SV055IS5-4N)
LG变频器SV008IS(SV008IS5-4N)
LG变频器SV037IS(SV037IS5-4N)
供应LG/LS PLC ( K7M-DRT30U)
Autonics奥托尼克(FX5S-I,FX4S)
韩国LG/LS产电PLC(G6L-ERFC)
天津Autonics计数(LA7N-1R,LA7N-2R)
