ADA16-8/2(LPCI)L窄卡PCI总线廉价高精度非隔离模拟量I/O接口
ADAI16-8/2(LPCI)L窄卡PCI总线廉价高精度隔离型模拟量I/O接口板
ADA16-8/2(LPCI)L窄卡PCI总线廉价高精度非隔离模拟量I/O接口板This product is a PCI bus compatible interface board with high-precision analog input(16-bit,8 ch) and output(16 bit, 2 ch), digital input and output channels (4 channels each), and a 32-bit counter(1 channel). Windows Driver Library API-PAC(W32) /Linux driver API-AIO(LNX) is Bundled. It can also collect data easily without a program when the data logger software [C-LOGGER] stored on the attached CD-ROM is used. With plug-ins for the dedicated libraries, the board also supports MATLAB and LabVIEW.
ADAI16-8/2(LPCI)L窄卡PCI总线廉价高精度隔离型模拟量I/O接口板This product is a PCI bus compatible interface board with high-precision analog input(16-bit,8 ch) and output(16 bit, 2 ch), digital input and output channels (4 channels each), and a 32-bit counter(1 channel). Noise characteristics-resistant improve by the bus isolation. Windows Driver Library API-PAC(W32) /Linux driver API-AIO(LNX) is Bundled. It can also collect data easily without a program when the data logger software [C-LOGGER] stored on the attached CD-ROM is used. With plug-ins for the dedicated libraries, the board also supports MATLAB and LabVIEW.
