● COM Express CPU模块采用 Intel 965GME 芯片组,支持Intel Core 2 Duo T7500 2.2GHz处理器
● 两个DDRII SODIMM 插槽, 最大支持4GB内存
● COM x 4, USB 2.0 x 4
● 4个千兆RJ-45网口
● 2个SATA-II接口,2个2.5寸硬盘架
● DVI-I x 1(VGA By Y Cable)
● MXM Support-PCI-Express界面的图形处理器接口
● 两个PCI扩展
● ATX Power Function-ATX方式供电
系统规格
Processor-Intel T7500 2.2GHz processor
System Memory-DDRII SDRAM SODIMM x 2, Max. 4GB.
Expansion-PCI x 2
VGA/ Keyboard/ Mouse -DVI-I x 1 (DB-15 VGA Connector by VGA adapter), PS/2 Keyboard & Mouse x 1
Ethernet-Gigabit Ethernet, RJ-45 x 4
SSD-CompactFlash Socket x 1
Hard Disk Storage-SATA/IDE Hard Disk Drive bracket x 2(SATA II Port x2 Support Raid 0/Raid 1)
Serial Port-COM x 4(RS232/422/485x2, RS232x2)
Audio-Line-in x 1, Line-out x 1, Mic-in x 1 by extend cable
USB-USB2.0 x 4
System Control-Power switch x 1,Reset switch x 1
LED Indicator-Power LED x 1, Hard Disk Drive LED x 1
Watchdog Timer-Generates a Time-out System Reset, setting via Software
Power Supply-1. ATX Power function
2. DC Input 9-30 (Phoenix connector 3 pin)
3. Power Board Support (80W)operation output
4. Optional AC power adapter , input voltage range 100~240 V
Power Consumption-Intel Core 2 Duo 2.2GHz (T7500), 1.97A @ DC19V+17W=53.43W
MTBF (Hours)-32,000
OS Support-Windows CE 6.0, Windows XP Pro, Windows XP Embedded, Linux Red Hat, Windows Vista
结构规格
Construction-Rugged Aluminum Alloy Chassis
Color-White & Black
Mounting-Wall mount/Desk top
Dimension-214mm x 99.2mmx 237.5mm
Net Weight-5.63Kg
环境规格
Operating Temperature--15℃ ~ 60℃ (CFD with a RAM Module)
-10℃ ~ 55℃( Hard Disk Drive with a RAM Module)
Storage Temperature--20℃ ~ 70℃
Storage Humidity-5 ~ 95% @ 40℃, non-condensing
Vibration-5g rms / 5 ~ 500Hz / operation CFD
1g rms / 5 ~ 500Hz / operation HDD
Shock-50g peak acceleration (11 msec. duration) CFD
EMC-CE/FCC Class A
