产品介绍: |
| General |
| Processor |
Intel Atom 1.6GHz Z530 CPU |
| Chipset |
Intel SCH US 15w |
| Memory |
System Memory 512M built-in, Support up to 1GB DDR2 400/533MHz SDRAM |
| Ethemet |
RJ-45 10/100Base-T support wake on LAN function
2-pin LAN LED header |
| super I/O |
1*winbond 83627HG by LPC |
| watchdog |
software programmable support 1!255 sec system reset |
| BIOS |
AMI system BIOS
Advanced power management support 8M bits flash ROM |
| connector |
2*2*50pin connector for connect to PB-701 |
| Mechanical Specificatons |
| Structure |
Aluminums, power coat w/silk screen (customer logo) |
| Dimension |
120*75*35mm (W*H*D) |
| Gross weight |
TBD kg |
| packing Filler |
PE |
| cooling |
Fan less |
| Mount |
wall mount |
| Operation temperature |
0C to 60C ( normal), -30C to 80C (wide temp) |
| relative Humidity |
operation 10%~90%, non-condensing
Non-operating 5%~95%, non-condensing |
| operation Humidity |
10%~90%, non-condensing |
| storage Humidity |
| EMI /safety |
meet CE/FCC Class A, RoHS component and process |
