产品介绍: |
The MOXA EDS-82810G is a high-performance Layer 3 Ethernet switch designed for network routing. The improved hardware technology built into the MOXA EDS-82810G replaces the software logic used by traditional routers, offering better performance, and making the switch ideal for largescale local area networks (LANs). In addition to Layer 3 features, the MOXA EDS-82810G also supports Layer 2 management features, including QoS, IGMP snooping/GMRP, VLAN, LACP, SNMPv1/v2c/v3, RMON, IEEE 802.1X, HTTPS, and SSH. In order to meet the demands of any industrial application, the MOXA EDS-82810G uses a modular design that allows users to install up to 4 Gigabit Ethernet ports and 24 fast Ethernet ports, providing a high degree of flexibility for network expansion.
