产品名称: Mini-ITX IX45GM2
型  号: IX45GM2
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® Socket P supports Core™2 Quad/ Core™2 Duo/ Celeron® M with 45nm process technology
FSB
1066/800/667 MHz
BIOS
AMI 32Mb BIOS
System Chipset
Intel GM45 + ICH9M-E
I/O Chip
Winbond W83627DHG-A+Fintek 81216G
System Memory
2 200-pin SODIMM sockets support up to 4GB Dual Channel DDR2 800MHz SDRAM
SSD
One Compact Flash Type I/II Socket (optional)
Watchdog Timer
Reset: 1 sec. to 255 sec/min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 Mini PCI-E, 1 PCI-E x 1, 1 PCI 2.3
TPM
Intel Integrated TPM 1.2
S1/S2/S3
Yes
SmartFan Control
Yes
I/O
MIO
4 SATA II, 8 USB, 5 RS-232, 1 PS/2 Keyboard+Mouse
USB
8 USB 2.0
GPIO
16-bit General Purpose I/O for 8-bit DI and 8-bit DO
Display
Chipset
Intel 65nm Mobile GMCH Integrated Graphics 4500MHD
Display Memory
Intel DVMT 5.0 supports up to 512MB Video Memory
Resolution
2048 x 1536 @ 75 MHz
Dual Display
VGA+HDMI, LVDS+HDMI, VGA+DVI, LVDS+DVI
HDMI
On Board
LVDS
Dual channel 24-bit LVDS
DVI
TI SN75DP139 DisplayPort to TMDS Transmitter
Audio
Audio Codec
Realtek ALC888, 5.1+2 CH HD Audio
6W x 2-CH Amplified
Audio Interface
Mic-in, Line-in, Line-out
Ethernet
LAN 1
Intel 82567LM Gigabit LAN
LAN 2
Intel 82574L PCI-E Gigabit LAN for 2nd LAN (Optional)
Back Panel I/O Port
Back Panel I/O Port
1 PS/2 Keyboard+Mouse (Through Y-Cable)
1 RS-232 with 5V/12V power
1 VGA port
1 DVI port
1 HDMI port
4 USB 2.0/1.1
1 LAN RJ45 ports (2nd LAN optional)
Audio I/O (3 jacks)
Internal I/O Connector
2 USB Connectors support Additional 4 USB Ports
1 24-pin ATX Power
4 COM Port Headers (no box), 1 with 5V/12V Power
4 SATA Connectors
1 Audio Amplifier Connector
1 Front Audio
1 Front Panel
1 S/PDIF Out
1 LVDS Connector
1 Inverter Power Connector
1 CPU Fan Connector
1 System Fan Connector
1 Digital IO Header
Mechanical & Environmental
Power Requirement
0.591A@19V (with Core 2 Duo T7100 1.8GHz & 1GB DDR2 SDRAM)
Power Type
ATX
Operating Temperature
0 to 60°C (32 to 140°F)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88lbs (0.4Kg)
Ordering Information
IX45GM2
Intel GM45 Mini-ITX Motherboard with VGA, DVI, HDMI, Audio, Dual Gb LAN, 5 COM, 4 SATA ,8 USB, 1 Mini PCI-E, 1 PCI-E x 1, 1 PCI 2.3 & 16-bit DIO
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
