产品名称: Mini ITX IX910GMLE2
型  号: IX910GMLE2
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Socket 478 type
FSB
400 MHz
BIOS
Award 4 Mb Flash ROM BIOS
System Chipset
Intel 82910GMLE GMCH/82801FBM ICH6-M
I/O Chip
Winbond W83627DHG-A
System Memory
Two 240-pin SO DIMM socket supports up to
2 GB DDR2 400 SDRAM
SSD
One Compact Flash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature and cooling fan status Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant) supports 3 PCI master
S3
S3 Support
SmartFan Control
Yes
I/O
MIO
1 xEIDE (Ultra DMA 100), 2 x SATA, 8 x RS-232,
1 x K/B, 1 x Mouse
COM
COM1/2/3/4/ 5/6 ports as RS-232 ; COM1/2/3/4
pin-9 with +5V & +12V powered,COM 7/8 as RS232/422/485 by jumper
USB
8 x USB 2.0
DIO
16-bit General Purpose I/O for DI and DO
(8 in/8 out with 2.0 pin header)
Display
Chipset
Intel 82910GMLE GMCH integrated Graphics
Media Accelerator 900
Display Memory
Intel DVMT 3.0 supports up to 128 MB video memory
Resolution
2048 x 1536 @ 32 bpp (75 Hz)
Dual Display
CRT + LVDS
LVDS
Dual-channel 18-24bit LVDS
Audio
Audio Codec
Realtek ALC655 supports 5.1 ch. Audio
Audio Interface
Mic in, Line in,Line out
Ethernet
LAN 1
Realtek RTL8110SC Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 2 x RS-232/1 x VGA port / 4 x USB 2.0/1.1 / 1 x RJ45 Port
5.1 CH Audio I/O (3 jacks)
Internal I/O Connector
* 2 x USB connectors support additional 4 USB ports
* 1 x 20-pin ATX Power connector
* 1 x IDE 40-pin connector for two devices
* 6 x COM port header (2.0 by 36 pin for Com 3 to Com 6,
2.0 by 9pin for Com 7 and Com 8)
* 2 x SATA connectors
* 1 x System panel connector
* 1 x LPT SPP/ECP/EPP with 26-pin 2.54 pitch box-header
* 1 x LVDS connector
* 1 x Inverter Power connector
* 1 x CPU Fan connector
* 1 x System Fan connector
* 1 x Digital IO header
Mechanical & Environmental
Power Type
TBD
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
1.1 lbs (0.5 kg)
Ordering Information
IX910GMLE2
Mini ITX Main Board with VGA, 1-CH LVDS,Audio, Gb LAN, 8 COM,8 USB 2.0& 1 PCI
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
