产品名称: Micro ATX MX45Q
型  号: MX45Q
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel LGA775 socket for Intel Core 2 Quad / Core 2 Duo Processors with Intel 45nm
processor technology, TDP 95W
FSB
1333 / 1066 / 800 MHz
BIOS
Award 32 Mb SPI BIOS
System Chipset
Intel Q45 GMCH / ICH10DO
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to 8 GB
Dual Channel DDR2 533/667/800 non-ECC, un-buffered memory
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
1 x PCI-E 2.0 X16, 1 X PCI-Ex1, 2 x PCI (PCI Rev. 2.3 compliant)
S3/S4
Yes
TPM
Intel® Integrated TPM1.2
Wake up Mode
Supports LAN (PXE / RPL)
SmartFan Control
Supports 3 modes in Silent / Optimal / Performance modes
I/O
MIO
1 x EIDE, 6 x SATA/SATAII, 2 x RS-232 (5V/12V),
1 x LPT port, 1 x PS2 KB/MS
USB
12 x USB 2.0
DIO
16-bit DIO (8-bit in and 8-bit out)
Display
Chipset
Intel® Graphics Media Accelerator 4500 integrated
Display Memory
Intel® DVMT 4.0 supports up to 352 MB video memory
Max. Resolution
2048 x 1536 @ 32 bpp (75Hz)
VGA
Yes , on board GMA 4500
LVDS
Through ADD2 LVDS Card
DVI
Through ADD2 DVI Card
HDMI
Through ADD2 HDMI Card
Secondary VGA
Through ADD2 VGA Card
Audio
Audio Code
Realtek ALC888 high-definition Audio Codec
supports 5.1+2-CH two independent Audio streams
Audio Interface
Line-out, Line-in, Mic-in,SPDIF header
Ethernet
LAN 1
Intel® 82567-LM PCI-E Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 1 x VGA port/ 1 x LPT port / 1 x COM Port / 1 x RJ45 port
4 x USB 2.0/1.1 / 1 x Audio Jack (3 ports)
Internal I/O Connector
4 x USB connectors support additional 8 USB ports
1 x IDE connector
6 x SATA connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x Front panel header
1 x S/PDIF Out Header
1 x Chassis Intrusion header
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
1 x 4-pin Audio Amplifier
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~50°C (32~122°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
9.6” x 9.6” (243.84 mm x 243.84 mm)
Weight
1.35 lbs (0.6 Kg)
Ordering Information
MX45Q
Intel Q45 LGA775 Micro ATX Motherboard with VGA, Audio, Gb LAN, 2 COM, 6 SATA, 12 USB, 1 PCI-E2.0 X16, 1 PCI-EX1, 2 PCI, 16-bit DIO
关 键 词: 必升 嵌入式主板
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
