产品名称: ATX AX35Q
型  号: AX35Q
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
LGA775 socket supports Intel Core™2 Quad
Core™2 Duo Processors with 45nm process technology
FSB
1333 / 1066 / 800 MHz
BIOS
AMI 16Mb SPI BIOS
System Chipset
Intel Q35 GMCH / ICH9DO
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to 8 GB
Dual Channel DDR2 800/667 SDRAM, non-ECC
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, one PCI Express X 1,
Five PCI (PCI Rev. 2.3 compliant)
S3/S4
Yes
TPM
TPM1.2 (Infineon TPM chip 9635 TT 1.2 on board)
Wake up Mode
LAN mode (PME / RPL)
SmartFan Control
Support 3 modes (Slient/Optimal/Performannce)
I/O
MIO
1 x EIDE 66/100/133, 6 x SATA II, 1 x LPT, 1 x FDD, 4 x RS-232 (5V/12V output) , 1x K/B, 1 x Mouse
USB
12 x USB 2.0
e-SATA
16 bit DIO (8-in/8-out by PCA9555)
Display
Chipset
Intel Q35 GMCH integrated Graphics Media
Accelerator 3100
Display Memory
Intel DVMT 4.0 supports up to 284MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75Hz)
VGA
on board GMA 3100
HDMI
Through ADD2 HDMI Card
LVDS
Through ADD2 LVDS Card
DVI
Through ADD2 DVI Card
Secondary VGA
Through ADD2 VGA Card
Audio
Audio Codec
Realtek ALC888 w/o Multiple streaming or
5.1+2-CH multiple streamings HD Audio
Audio Interface
Mic in, Line in, CD Audio in, Line out
Audio Amplifer
Dual 6W AMP (TPA3005D2, Optional)
Ethernet
LAN 1
Realtek RTL8111C PCI-E Gigabit Ethernet Controller
LAN 2
Back Panel I/O Port
Back Panel I/O Port
1 x PS/2 Keyboard / 1 x PS/2 Mouse / 1 x VGA port/ 1 x Parallel port / 1 x COM Port / 2 x RJ45 port/ 4 x USB 2.0/1.1 / Audio Jack (3 ports)
Internal I/O Connector
* 4 x USB connectors support additional 8 USB ports (with 5V dual)
* 1 x Floppy disk drive connector
* 1 x IDE connector
* 6 x SATA connectors
* 1 x CPU Fan header (support PWM & DC fan)
* 1 x Chassis Fan header (support DC fan only)
* 1 x Power Fan
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
Intel Q35 LGA775 Core™2 Quad ATX
Motherboard with VGA, Audio, Dual Gb LAN, 4 COM, 12 USB, 1 PCI-Ex16, 1 PCI-Ex1, 5 PCI, TPM, 16-bit DIO & 6W AMP
关 键 词: 嵌入式主板 AX35Q
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
