产品名称: Nano ITX NXLNP
型  号: NXLNP
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel® AtomTM N450 SC/ D410 SC/ D510 DC 1.6GHz Processor
FSB
DMI (2.5Gbps) x 4 Lanes
BIOS
AMI/Legacy 16 Mb SPI BIOS
System Chipset
Intel® ICH8M
I/O Chip
Winbond W83627DHG-A
System Memory
One 200-pin SODIMM socket supports up to 2GB DDR2 800MHz(D510)/ 667MHz (D410/ N450) SDRAM
Watchdog Timer
Reset: 1 to 255 sec/min per step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats.
Expansion
1 Mini PCI-E, 1 CF
Power State
S1, S3, S4, S5
TPM
Onboard TPM 1.2 by Infineon SLB9635 (optional)
Wake up on LAN or Ring
LAN (PXE), Ring (COM 1/2)
SmartFan Control
Supports 3 modes (Silent/Optimal/Performance)
I/O
MIO
2 SATA II, 2 COM RS-232, 1 PS/2 Keyboard, 1 PS/2 Mouse
USB
6 USB 2.0
GPIO
8-bit General Purpose I/O for 4-bit DI and 4-bit DO
Display
Chipset
Integrated Intel® Gen3.5+GFX Render Core 200MHz (N450/D410)/400MHz (D510)
Display Memory
Shared Memory Max 224MB
Max. Resolution
LVDS : Max 1280 x 800 or 1366 x 768
VGA : Max 2048 x 1536 @ 60Hz
Dual Display
LVDS+VGA
VGA
On board
LVDS
18-bit Single Channel LVDS
LVDS Backlight
5V and 12V
Audio
Audio Codec
Realtek ALC888, 5.1 + 2 CH HD Audio
Audio Interface
Line-in, Line-out, Mic-in
Ethernet
Ethernet
Realtek RTL8111C Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 PS/2 Keyboard+Mouse,
1 VGA Port,
1 LAN RJ45 Port,
2 USB 2.0 Ports,
1 Line-out,
1 12V DC-in
Internal I/O Connector
2 COM RS-232 Ports w/ Power,
1 CPU Fan Connector,
1 Front Panel Header supports 2 USB Ports,
1 USB Connector supports 2 USB Ports,
1 18-bit LVDS Connector,
1 LVDS Invertor Connector,
2 SATA II Connectors,
1 CF Socket (on the back),
1 Digital I/O Header,
1 Mic-in & Line-in Header,
1 Mini PCI-E
Mechanical & Environmental
Power Requirement
+12V (3A)
Power Connector
12V CPU Fan Connector
Operating Temperature
0 to 60°C (32 to 140°F)
Operating Humidity
0% to 90% relative humidity, non-condensing
Size (L x W)
4.72” x 4.72” (120 mm x 120 mm)
Weight
0.31 lbs (0.13Kg)/ 0.5 lbs (0.24Kg) with Fan
Ordering Information
NXLNP
90N-LNP000-M1000B2
NXLNP-N450 Nano-ITX Motherboard
90N-LNP000-M1001B2
NXLNP-D410 Nano-ITX Motherboard
90N-LNP000-M1002B2
NXLNP-D510 Nano-ITX Motherboard
关 键 词: 嵌入式主板 NXLNP
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
