产品名称: Nano ITX NX700CXM
型  号: NX700CXM
品  牌: 必升
Download
Product Spec [PDF]
Manual & Drivers
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Supports VIA C7 / Eden / Eden ULV Processo
FSB
400 MHz
BIOS
Award 4 Mb Flash ROM BIOS
System Chipset
VIA CX700M
I/O Chip
Winbond W83627DHG-A
System Memory
One 200-pin SODIMM socket supports up to 1 GB DDR2 400 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One Mini-PCI, One CF Type I/II
Wake up on LAN/Ring
Supports LAN and Ring modes (COM w/o power when WOR)
S1 / S3
Supports both S1 and S3
SmartFan Control
Supports 3 modes in Silent / Optimal Performance modes
I/O
MIO
1 x STATII, 1 x RS-232, 1 x K/B, 1 x Mouse
USB
4 x USB 2.0
GPIO
8-bit General Purpose I/O for 4-bit DI and 4-bit DO
Display
Chipset
Integrated VIA UniChrome Pro II 3D/2D graphics and video processor
Display Memory
VIA S3 UniChrome Pro II 3D Graphic Engine Shared system memory up to 128MB
Resolution
VGA: 1920 x 1440 @75Hz
Dual Display
VGA + LVDS
LVDS
Dual channel 24-bit LVDS
Audio
Chipset
VIA CX700M
Audio codec
Realtek ACL888
Audio Interface
Mic in , Line out , Line in pin header
Ethernet
LAN 1
Realtek RTL 81110SC Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
1 x Mini Din (KB/Mouse) / 1 x VGA port
2 x USB 2.0/1.1 / 1 x RJ45 port / Audio I/O (2 jacks )
Internal I/O Connector
1 x USB connector supports additional 2 USB ports
1 x 6-pin ATX compatible power connector
1 x COM port pin header
1 x LVDS connector
1 x CPU Fan connector
1 x GPIO connector
1 x SATA II pin header
1 x ext Line-in connector
1 x Line-in connector
Mechanical & Environmental
Power Type
6 pin ATX compatible power connector(optional DC-DC power board)
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
4.72” x 4.72” (120 mm x 120 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
NX700CXM. VIA CX700M Nano-ITX Motherboard with VGA, LVDS, Audio, GigaLAN, Mini-PCI, CF, COM, 4 USB, 1 SATA II, 8-bit GPIO
关 键 词: 嵌入式主板 NX700CXM
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
Compact Flas
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
