产品名称: Compact Flash Card
型  号:
品  牌: 必升
Compact Flash Card
· Capacity 1 GB ~ 16 GB
· Supports SLC (single level cell) NAND Flash Memory
· Supports PIO Mode 6 / Multi Word DMA Mode 2 / Ultra DMA Mode 5
· Supports Security ID & S.M.A.R.T.
Capacity
1 G/ 2 G/ 4 G/ 8 G/ 16 GB
Compatibility
CF 3.0, PC Card, Socket’s Services
Form Factor
CF Type-I
Voltage
3.3 V / 5.0 V
Data Transfer Mode
PIO Mode-6
MWDMA Mode-2
UDMA Mode-5
Sustained R/W Performance
2 channel: 43/30 MB per second
1 channel: 22/15 MB per second
Operation Temperature
Commercial Grade: 0 to +70° C
Extended Grade: -40 to +85° C
Host interface
8/16 bit access
ECC (BCH)
Correct up to 6/12 random bits/sector
MTBF
>1,000,000 hours
Vibration resistance
16.5 G
Shock resistance
1,100 G (0.5 msec)
Security Feature Set
Security Disable Password
Security Erase Prepare
Security Erase Unit
Security Freeze Lock
Security Set Password
Security Unlock
Software Spec.
1.
Product key protected GUI Management Tool
2.
GUI Management Tool User Interface
3.
Encrypted Application Programming Interface (API) support
4.
Security ID Read/Write and protecting sample code generator
5.
Get S.M.A.R.T. attribute
Ordering Information
CF1G/ 968EMS0037/ BCM CFCard 1G CF NR, DMA (0~70°C)
CF2G/ 968EMS0038/ BCM CFCard 2G CF NR, DMA (0~70°C)
CF4G/ 968EMS0039/ BCM CFCard 4G CF NR, DMA (0~70°C)
CF8G/ 968EMS0040/ BCM CFCard 8G CF NR, DMA (0~70°C)
CF16G/ 968EMS0041/ BCM CFCard 16G CF NR, DMA (0~70°C)
CF1G-E/ 968EMS0042/ BCM CFCard 1G CF NR, DMA (-40~85°C)
CF2G-E/ 968EMS0043/ BCM CFCard 2G CF NR, DMA (-40~85°C)
CF8G-E/ 968EMS0045/ BCM CFCard 8G CF NR, DMA (-40~85°C)
CF16G-E/ 968EMS0046/ BCM CFCard 16G CF NR, DMA (-40~85°C)
关 键 词: 必升 Compact Flash Card
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 8862-27961888
手  机:
地  址: 台北市内湖区瑞光路26巷20弄1号6楼
邮  编: 114
VGA Card AD-(AD-8001)
Embedded PC (FCX230)
Embedded PC (FCX231)
Embedded PC (ACX430)
Embedded PC (ECX330)
Embedded PC (ECX331)
Embedded PC (TCX120)
Embedded PC (ELF-500)
Embedded PC (ELF-300)
Embedded PC (ELF-310)
Nano ITX NX7(NX700CXM)
Nano ITX NX1(NX15MXL)
Nano ITX NX1(NX15MXL2)
Nano ITX NXL(NXLNP)
ATX AX35Q(AX35Q)
ATX AX45Q(AX45Q)
ATX AX45Q2(AX45Q2)
ATX BV945GR(BV945GR)
ATX AX45Q3(AX45Q3)
