产品名称: 工控机
型  号: BOX-ACS2695
价  格:
品  牌: aplex
Specifications:
Display Specifications
Processor  Support Socket G2, 2nd Generation Intel Core i7/i5/i3
System Memory  2 x 204 Pin DDR3 SO-DIMM, default 4GB (one slot), up to 16GB 1066/1333MHz
System Chipset  Intel QM67 PCH
External I/O Port  2 x DB9 RS-232 (COM1.2)
1 x DVI-I
1 x HDMI
2 x RJ45 GbE LAN
4 x USB 2.0
1 x Mic-in, Line-Out
1 x DC Power 3 Pin terminal block connector
1 x 2 pin power switch connector
2 x LED indication
1 x Power button switch
1 x COM 422/485 (COM3, default:RS-485)
1 x COM RS-232 (COM4)
1 x 10 Pin terminal block for 1 Ground/VCC/4 in & out DIDO
Storage  2 x 2.5" SATA HDD space
1 x external CF slot
Expansion Slot  1 x PCIe x 16 and 1 x PCI slot
OS Support  Windows XP Embedded, Windows Embedded Standard 7, Windows 7 Pro for Embedded
Power Input  DC 9~32V
CD/DVD-R Device  Optional
Wireless  2 x antenna holes at front side for option
Optional Fan  2 x 40 x 40 mm System Fan space (rear and front)
Mechanical Specifications
Construction  Steel and Aluminum Heat sink
Dimensions  211.2 x 203.5 x 126
   211.2 x 203.5 x 148 (with DVD device)
Mounting  Wall Mount, optional Din Rail Mounting
Weight  2.5 kgs
Environment Specifications
Operating Temp.  0~50 °C
Storage Temp.  -20~60 °C
Storage humidity  10~90%@ 40 °C, non-condensing
Certificate  CE/FCC Class A
关 键 词: 嵌入式工控机 可扩展插槽 高性能
公司名称: 上海迅泓计算机科技有限公司
联 系 人: 宋建峰
电  话: 021-64547292
手  机: 13524148825
地  址: 上海市虹梅南路986号掘金大厦602
邮  编: 200237
双485串口卡(IPC-P2102SI)
数字量输入接口板(康泰克PI-32L(PCI)H)
康泰克工控机(950系列嵌入式工控机)
InnoDisk固态硬盘(SATA 25000)
