产品名称: 进口恒温混水阀品牌,参数
型  号: LIPH
进口恒温混水阀
德国雷普LIP恒温混水阀由中国深圳派克阀门有限公司总代理
德国雷普LIP阀门严格按照ISO9001质量管理体系进行生产过程控制,保证阀门的每个组件都达到要求,并进行严格的成品测试,从而保证到用户的每件阀门产品都是合格产品。
Germany LIP valve rep in strict accordance with the ISO9001 quality management system and production process control, to ensure that each component of the valve can meet the requirements, and strict product testing, to ensure that every user to valve products are qualified products.
型号:LIP
德国雷普恒温混水阀是专为热水系统研制的配套产品,广泛应用于太阳能热水器、集中热水系统及电热水器等。
用户可以根据需要自行调节冷热水混水温度,所需温度可以迅速达到并且稳定下来,保证出水温度恒定,且不受水温、流量、水压变化的影响,解决使用热水时水温忽冷忽热的问题,冷水一旦中断,热水自动停止;热水一旦中断,冷水也会自动关闭,防烫伤、防冷激。可在家庭生活热水、饭店、医院、学校等要求提供稳定供水温度的中、小型生活热水系统中使用。
Germany leipold thermostatic mixing valve is designed for the hot water system and auxiliary products, widely used in solar water heater, central hot water system and the electric water heater.
The user can adjust the mixing of hot and cold water temperature according to the need, the required temperature can be achieved quickly and stable, ensure the water temperature constant, and is not affected by water temperature, flow, pressure,
temperature of the solution to the problem sometimes hot and sometimes cold with hot water, cold water in the hot water once broken, automatic stop; hot water once interrupted, cold water will automatically shut down, anti scald, prevent cold shock. In the domestic hot water, hotel, hospital, school and other requirements to provide a stable supply water temperature of the medium and small living hot water system in the.
在恒温混水阀的混水出口处,装配有热敏感温组件,水温变化使热敏组件膨胀或收缩控制阀内阀芯移动,封堵或者开启冷、热水的进水口。当温度调节旋钮设定某一温度后,混水阀通过调节进入出水口的冷热水比例,使出水温度始终保持恒定。不会受热水温度的降低、用水量的增减或水压变化的影响。
In the mixed water outlet thermostatic mixing valve, fitted with the thermosensitive temperature sensing component, the component temperature thermal expansion or contraction control mobile spool valve, inlet seal or open the cold, hot water. When the temperature control knob to set a temperature, hot and cold water mixing valve through proportional control into the outlet, the outlet temperature is always constant. Not affected by reducing the temperature of hot water, with water or water pressure changes.
进口恒温混水阀在太阳能系统上的应用Application of import thermostatic valve in the solar system.
太阳能热水器公司为了使用户冬天早上能洗上热水澡,都大大地提高了集热能力!但冬季的热量达到了“标准”,夏季、秋季的热量就会过剩,超高温热水输出的现象就不可避免!造成消费者使用不当而引发的烫伤案例也屡见不鲜。遗憾的是没有厂家去考虑太阳能热水器防烫安全的问题,在日照充分或多天不用情况下,落水式太阳能热水器的最高输出水温可以达到100℃,承压式甚至会更高,因此对选用的热水管也必须是耐高温的,这样不但提高了成本,还留下了隐患。要是应用了恒温混水阀问题就迎刃而解,不用考虑热水是80℃还是100℃,只要将恒温阀设定为40℃,那么就会得到40℃的出水。
Solar water heater company in order to winter morning to wash the hot bath, can greatly improve the heat collecting capacity! But the winter heat to achieve a "standard", the excess heat in summer and autumn will, ultra high temperature hot water output phenomenon is inevitable! Due to improper use of consumers caused by burn cases are not uncommon. Unfortunately there is no manufacturers to consider the safety of the solar water heater hot issues in full sunshine or more days without conditions,
the highest output water temperature water type solar water heater can reach 100 DEG C and the pressure will be even greater, so the choice of hot water pipe must also be resistant to high temperature, which not only improves the the cost, but also left a hidden danger. If the application of thermostatic mixing valve problem is solved, regardless of water is 80 degrees or 100 degrees, as long as the thermostatic valve set at 40 C, 40 C would.
制造标准:美标、国标、德标
产品产地:德国
产品品牌:德国雷普《LIP》
关 键 词: 进口恒温混水阀 进口恒温混水阀T图 进口恒温混水阀
公司名称: 深圳派克工业阀门有限公司
联 系 人: 林生
电  话: 0755-81713669
手  机: 13827443669
地  址: 龙华新区墩背工业区18号
邮  编: 518109
进口电动保温球阀进口高温(LIPQ)
进口沼气防爆电磁阀(LIPD)
进口高压液体安全阀(LIPA)
进口超高温电磁阀(LIPD)
进口气动法兰球阀(价格)(LIPQ)
进口卫生级减压阀(LIPY)
进口高粘度高压电磁阀(LIPD)
进口防腐蚀电磁阀(LIPD)
进口高温不锈钢减压阀(LIPY)
进口高粘度高压球阀(LIPQ)
进口电动三通球阀(图片)(LIPQ)
进口高温合金钢安全阀(LIPA)
进口高压德标安全阀(LIPA)
进口高粘度电磁阀(图片)(LIPD)
进口安全溢流阀(LIPA)
进口卫生级安全阀进口制药(LIPA)
进口高压直动式电磁阀(LIPD)
进口耐酸碱球阀品牌(LIPQ)
